From those pics it looks like there is about $2500 worth of damage. Some c*nt backed into the front of mine not long ago and took out 1 headlight and pushed the bumper slightly out of whack. It took a $1200 bill to fix it. I'm lucky insurance covered it. The headlight was $538 alone!
im on 3rd party fire and theft only. i have to foot the bill for this one. im gonna prob beat out the bonnet. i figured the damage was worth that much tho. it sucks major a**
riggaP, whered u get urs fixed? im trying to find some good smash repairers around. i dont know of any import specialists ones.
Sorry 2 say mate but the GTR bar doesn't fit on a GtsT without some major mods......GTR is wider than a Gtst therefore bar width has to be reduced.....
They say minor mods? but it can be done.. Jetspeed is useless at telling you exactly how they adapt it to fit, just that it don't fit straight on.
Dj_l3thal spoke to IQ Auto and they said it was an "easy" job to heat melt it into the right shape.
i was under the impression getting gts't GTR Front bars was quite easy? As in, quite a few places have them, and they are made to fit GTS'T's only?
Just wish there was a R34 GTR front bars for GT-T's!! :D
your looking at around $1500 to fix that + the price of a new front bar. u need by the looks of it a new re-enforcement bar, headlights(are they craked)? i did the same thing to my car not a Skyline rather a holden(hold the laughs) i got quoted between $1600 and $1100, but i went to a mates panel beatters in Ivanoh(spelling) got it done for $600 cash but i didnt replace the headlights , they where craked down the bottom.
i can give u the contact details of this panel better if u want. just PM
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
