hey i just got me a bov and was wondering what to adjust it to. it has a screw on it but im not sure what the difference between adjusting it to, to me loosening it make a hissing noise.
also when installed i rev it and hear 1 or 2 flutters from my pod but the bov opens at the same time. i know it opens coz i can feel the air on my hand [self reved from the engine bay]
thanks
also i have searched and after a reading "bovs are gay and blah blah blah" cant really find this info.
https://www.sau.com.au/forums/topic/245430-hks-ssq-adjustment/
If it's a genuine HKS SSQV it doesn't have an adjusting screw in it as it's not required.
Cheers
Marty
only the new ones have no screw..the older ones do have a screw
turning it clockwise will set it harder and anti clockwise will set it softer...the more boost your running the harder you set it
i installed a new one and it would stay open for too long and lag my turbo heaps... the older ones must have been heaps better with the adjusting screws..
Care to explain this as by design it can't happen.
It has a spring to hold it closed under light vacuum and only opens under high vacuum from the manifold. So as soon as you start opening the throttle again it is closed. It shouldn't have anything to do with making the turbo's laggy. If the BOV vents while boosting there is deffinately something wrong.
Cheers
Marty
Cheers
Marty
I bet you he will tell you its between gears lag,
I fitted a new HKS to a customers S14 SR20DET / T04z, from working perfectly with his old $20 knock off it started to fall right out of boost between gears unless I flat shifted with the HKS, it was replaced with a another unit, same problem....ripped the HKS out and fitted a Greddy RS and presto, no more problems.
so your saying that a BOV that releases the pressure inside the the inlet piping on gear change isnt working correctly?
since thats exactly what they are designed to do im not sure where the issue is, there should be lag from a system running a BOV as the turbo re-pressurises the piping.
Cheers
Marty
Well personally I don't think the new SSQs work well under high boost pressure.
With my current setup i have a HKS 2530kai and im running over 20psi with supporting mods. When i run that much boost with the SSQ it would stay open for a second or two after gear change, and the air would go into atmo instead of back into the plenum..
I'm not sure as to why this happened (too much vaccum under high boost pressure for the SSQ to handle?), but it only happened with the SSQ and not with any other atmo bov that I owned.
I've installed many atmo bovs and they all lagged my turbo in between gear changes (this is normal with atmo bovs).
Oh and I wouldn't have bought a bov if I intended on flat shifting 24/7.
Edited by EVL-R33
Craved, I am quite aware of how a bov works, as I said, lag between gears on the new SSQV was terrible compared to the RS, obviously the SSQV is prone to staying open longer or has slower/buffered piston movement than other name brand bov's.
EVL-R33
This is exactly what I am talking about, the SR20 in question was running close to 28psi and had an actual delay when shifting, knocks all the power out for a second or two like the bov doesnt close properly of fast enough,,, rip SSQV out and put in Greddy RS and presto no more problem... just regular minimal lag one expects from an abov...
has nothing to do with MAF either, all the cars I do now run VEMS or D-jetro.
In my opinion besides sounding retarded and looking gimiky the SSQV is just an expencive POS. Greddy, Tial or Synapse any day of the week for actual function which is what its there for.
Edited by Rezlo
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
