guys lets keep on topic. any owner of a specific vehicle will have pride on about their car. anyway if benzo came up with vq35 cruise then so be it...if not then it can be changed? its a SKYLINE forum and we're all members :P lets keep cool
this
thread cleaned.
guys do not whore the thread. most of you are regulars and you should know better.
you are free to create what ever cruise for what ever car model you like. no hate. just free love. hair AND sunshine.
https://www.sau.com.au/forums/topic/245432-vq35-cruise/#findComment-4272217
  • 1 month later...
interesting idea!
I have a couple of good maps ive made up for past cruises, if you want i will get one together, just pick a date (idealy we would want to avoid the next couple of weeks because of double demerits - not that anyone here would be speeding or anything :) )
Let me know what sort of map you would be after, im known for my good maps :banana:
https://www.sau.com.au/forums/topic/245432-vq35-cruise/#findComment-4336164
Hills are always good. Nothing worse than a cruise that's just a city based moving carpark. Aust Day Long weekend probably has d/demerits too. Sunday Feb 1st?
i like this date..cos i will be in perth..and i will have my car back :D
https://www.sau.com.au/forums/topic/245432-vq35-cruise/#findComment-4339172
Okay guys i'm TRYING to organise it. I've put it to some of 350z guys and they seem keen. But we have a bit of a problem a lot of them are Fly in / Fly out arrangement and trying to pick a date that everyone is in perth isn't really going to happen as rosters conflict etc.
So i'm going on a 'majority' rules now. So are any of you guys Fly in / Fly out? If so from 1st Feb to the end of March what dates will you be in perth? PM if you like that way the thread doesn't get wh0red up .... i can't be assed with a poll just for this.
Edited by Nizmo
https://www.sau.com.au/forums/topic/245432-vq35-cruise/#findComment-4343087
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
