ive changed my plugs, checked the coil packs, even checked the resistance of the coil packs with a multimeter. every thing seems to be normal. the miss is still there. only under a fair bit of load though, so it looks like im going to have to buy a s-afc
i think robo is right! it must be dumping to much fuel......
LastTemptation
i know what u mean dude, funny thing is i am a mechanic. (a heavy vehicle mechanic though) so i only know diesl!!!!
and electrical isnt one of my stong points.
i did check all the obvious things first, but its good to get other ppls opinions and maybe learn from others ppls experiences.
looks like i will have the problem sorted out when i get my hands on an apexi safc.
thanks for your help guys.
  • 2 months later...
walkoau, guess wat i have same problem wit mis fire... at 6000rpm..
wat did u do to fix it.. ur safc work good for it or wat?
i got quoted for a coil change at $400 just checking wit u before paying.
yeah the safc helped the problem but its still there cause i havent had the chance to get it tuned yet.
you should do a check on the coils yourself before paying to get new ones.
the best way to check shorting is in the dark.
Park up your car at night, start it, and have a look for the little blue sparks jumping onto things.
Get someone to rev the engine if you have to.
I did this on my Ford Fairmont (which I am selling, and buying a R33 R34 4 door skyline) and I could see the little blue sparks jumping from the leads to the engine head anything metal etc.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
