hey guys i have a few r32 parts need to get rid of
engine cross member with all power steer lines and pump $200 ono great for s13 rb20- 25
starter motor rb20 $80 ono
altornater $50 ono
gearbox cross member with mount $50 ono
gear box with tail sharft $450 can be used with sr20.....small mod.....no shifter has a quick shifter on it atm would like to keep it
r32 engine loom no cuts nothing missing $120 ono computer is extra
call Ryan anytime on 0422,984,791
location padstow way
https://www.sau.com.au/forums/topic/245443-rb20-parts/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
