I am in the process of building an RB30/26 and have my RB26 Block, CP 86.5mm pistons and std rods with ARP rod bolts up for grabs. I have pulled the block right down to confirm it's all in good order. The motor has done around 5-10,000km's since it was rebuilt. The block and crank were both prepped by ADVAN.
Specs are:
1.5mm oil restrictor
decked
oil return galaries enlarged
additional support to turbo oil outlet(most crack and leak coolant, very common)
86.5mm bores
Balanced Crank
Linished
Plus the usual ADVAN prep
rebalanced and prepped std rods
Both the motor and block are stamped and numbered by ADVAN. I'm sure ADVAN can bring up all the specs on there computer if you want to find out more, i'm sure there are other things they have done that I haven't listed.
I would fit new rings ,but, you could get away with the current ones if your on a budget. Good for 380rwkw no problems.
Includes
Block
Water pump
Crank
Craddle
Windage trays
CP forged pistons, rings, pins, clips(still assembled on rods)
Std Rods with ARP rod bolts
Located in Adelaide
Avail: next few days
Price: $1000 the lot
SMS or call 0413023669
or PM
oh, it's cheap...I've been out of the loop
happy to sell it quickly to pay for my new build.
I can arrange rings at cost
My Mechanic rang and recommended the rod bushes be changed also
I can arrange postage anywhere in Australia for a great rate door to door
can also arrange new bush, bearings, and rings fitted with block cross hatched ready to go at cost.
btw DANOOH has first dibs.
then in order of messages on my phone I guess
I won't be on mobile till after 1600 Adelaide time
Regards,
Matt
PS feel free to email me
[email protected] before 1600 today
Edited by BoostdR
Oh, it's also from a 1998 Series 3 Vspec.
i can give you the chassis number, engine number if you would like to confirm with the Nissan Fast software.
cheers.
Not really Adrian, i know Matt, but i also know that Pete doesnt enlarge oil galleries, use oil gallery restrictors or balance standard rods and cranks, hence the reason i asked
Your right he personally doesn't, he out sources those bits to be completed to his specs.
Anywho it's sold and paid for
Just for the record, Peter has not balanced any part of this engine, he has not enlarged oil return galleries nor fitted after market oil restrictors, i should know, i helped put this motor together. Peter does not believe it is needed when putting an engine together.
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
    • 75W90 GL5 is fine. If you aren't sure about the type get one with LSD additive.
    • Because you're effectively rushing the shift and forcing it to go in - with greater leverage against parts that don't _want_ to go together. Short shift = forcing the gear in harder. Also Redline Heavy Shockproof actively says not to use it in anything with Synchros. Well, it says "not recommended" which is basically as far as anyone will ever say in a product statement to "Do not use" Generally the Redline makes the gearbox feel great... until it fails faster. https://www.redlineoil.com/heavy-shockproof
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
