I am in the process of building an RB30/26 and have my RB26 Block, CP 86.5mm pistons and std rods with ARP rod bolts up for grabs. I have pulled the block right down to confirm it's all in good order. The motor has done around 5-10,000km's since it was rebuilt. The block and crank were both prepped by ADVAN.
Specs are:
1.5mm oil restrictor
decked
oil return galaries enlarged
additional support to turbo oil outlet(most crack and leak coolant, very common)
86.5mm bores
Balanced Crank
Linished
Plus the usual ADVAN prep
rebalanced and prepped std rods
Both the motor and block are stamped and numbered by ADVAN. I'm sure ADVAN can bring up all the specs on there computer if you want to find out more, i'm sure there are other things they have done that I haven't listed.
I would fit new rings ,but, you could get away with the current ones if your on a budget. Good for 380rwkw no problems.
Includes
Block
Water pump
Crank
Craddle
Windage trays
CP forged pistons, rings, pins, clips(still assembled on rods)
Std Rods with ARP rod bolts
Located in Adelaide
Avail: next few days
Price: $1000 the lot
SMS or call 0413023669
or PM
oh, it's cheap...I've been out of the loop
happy to sell it quickly to pay for my new build.
I can arrange rings at cost
My Mechanic rang and recommended the rod bushes be changed also
I can arrange postage anywhere in Australia for a great rate door to door
can also arrange new bush, bearings, and rings fitted with block cross hatched ready to go at cost.
btw DANOOH has first dibs.
then in order of messages on my phone I guess
I won't be on mobile till after 1600 Adelaide time
Regards,
Matt
PS feel free to email me
[email protected] before 1600 today
Edited by BoostdR
Oh, it's also from a 1998 Series 3 Vspec.
i can give you the chassis number, engine number if you would like to confirm with the Nissan Fast software.
cheers.
Not really Adrian, i know Matt, but i also know that Pete doesnt enlarge oil galleries, use oil gallery restrictors or balance standard rods and cranks, hence the reason i asked
Your right he personally doesn't, he out sources those bits to be completed to his specs.
Anywho it's sold and paid for
Just for the record, Peter has not balanced any part of this engine, he has not enlarged oil return galleries nor fitted after market oil restrictors, i should know, i helped put this motor together. Peter does not believe it is needed when putting an engine together.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
