I am in the process of building an RB30/26 and have my RB26 Block, CP 86.5mm pistons and std rods with ARP rod bolts up for grabs. I have pulled the block right down to confirm it's all in good order. The motor has done around 5-10,000km's since it was rebuilt. The block and crank were both prepped by ADVAN.
Specs are:
1.5mm oil restrictor
decked
oil return galaries enlarged
additional support to turbo oil outlet(most crack and leak coolant, very common)
86.5mm bores
Balanced Crank
Linished
Plus the usual ADVAN prep
rebalanced and prepped std rods
Both the motor and block are stamped and numbered by ADVAN. I'm sure ADVAN can bring up all the specs on there computer if you want to find out more, i'm sure there are other things they have done that I haven't listed.
I would fit new rings ,but, you could get away with the current ones if your on a budget. Good for 380rwkw no problems.
Includes
Block
Water pump
Crank
Craddle
Windage trays
CP forged pistons, rings, pins, clips(still assembled on rods)
Std Rods with ARP rod bolts
Located in Adelaide
Avail: next few days
Price: $1000 the lot
SMS or call 0413023669
or PM
oh, it's cheap...I've been out of the loop
happy to sell it quickly to pay for my new build.
I can arrange rings at cost
My Mechanic rang and recommended the rod bushes be changed also
I can arrange postage anywhere in Australia for a great rate door to door
can also arrange new bush, bearings, and rings fitted with block cross hatched ready to go at cost.
btw DANOOH has first dibs.
then in order of messages on my phone I guess
I won't be on mobile till after 1600 Adelaide time
Regards,
Matt
PS feel free to email me
matthew.fairweather@rlmgroup.com.au before 1600 today
Edited by BoostdR
Oh, it's also from a 1998 Series 3 Vspec.
i can give you the chassis number, engine number if you would like to confirm with the Nissan Fast software.
cheers.
Not really Adrian, i know Matt, but i also know that Pete doesnt enlarge oil galleries, use oil gallery restrictors or balance standard rods and cranks, hence the reason i asked
Your right he personally doesn't, he out sources those bits to be completed to his specs.
Anywho it's sold and paid for
Just for the record, Peter has not balanced any part of this engine, he has not enlarged oil return galleries nor fitted after market oil restrictors, i should know, i helped put this motor together. Peter does not believe it is needed when putting an engine together.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
