hi peeps,
to my understanding there are 3 types of set up you can have for twin turbos,
1) two small turbo running simultaneously producing more power
2) two small turbos, running at different peak boost ( i think I forgot)
3) one small turbo and one large turbo, so that the smaller one helps with reducing turbo lag
I read this long long time ago and can't remmeber which website its from, if someone can refer me to a website.
which one is the GTR? and what turbo size is it running?
cheers peep
https://www.sau.com.au/forums/topic/245491-gtr-twin-turbo-size-and-setup/
You forgot the 4th option... two freakin' massive hairdryers producing loads of serious tire-shredding power! :D
Edited by Samon
You forgot the 4th option... two freakin' massive hairdryers producing loads of serious tire-shredding power! :P
well, two large turbos will have running simultaneously will have the same setup as option 1. there are only 3 set up I'm quite sure
there is no such thing as option 2 mate. you cannot have 2 turbos running at different boost.
there are 2 types of twin turbo set-ups.
sequential
parallel
sequential set-ups have one small turbo and one larger turbo. the small turbo spools first and once the larger turbo is in it's efficiencey range it comes into play. these set-ups are quite complex and require some tricky valves etc to operate properly. My FD RX-7 has this set-up. when done properly they are quite good. the RX-7 pulls strongly from 2,000rpm, then it starts to taper off at 4500rpm as the small turbo is running out of puff, then at 5,000rpm the big turbo kicks in pulling hard to redline.
parallel set-ups use two equally sized turbos running together. they both run the same boost level. this is the GTR type set-up.
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
