SKY 34 Posted November 19, 2008 Share Posted November 19, 2008 hi peeps, to my understanding there are 3 types of set up you can have for twin turbos, 1) two small turbo running simultaneously producing more power 2) two small turbos, running at different peak boost ( i think I forgot) 3) one small turbo and one large turbo, so that the smaller one helps with reducing turbo lag I read this long long time ago and can't remmeber which website its from, if someone can refer me to a website. which one is the GTR? and what turbo size is it running? cheers peep Link to comment https://www.sau.com.au/forums/topic/245491-gtr-twin-turbo-size-and-setup/ Share on other sites More sharing options...
Samon Posted November 19, 2008 Share Posted November 19, 2008 (edited) to my understanding there are 3 types of set up you can have for twin turbos, 1) two small turbo running simultaneously producing more power 2) two small turbos, running at different peak boost ( i think I forgot) 3) one small turbo and one large turbo, so that the smaller one helps with reducing turbo lag You forgot the 4th option... two freakin' massive hairdryers producing loads of serious tire-shredding power! Edited November 19, 2008 by Samon Link to comment https://www.sau.com.au/forums/topic/245491-gtr-twin-turbo-size-and-setup/#findComment-4270805 Share on other sites More sharing options...
DLOOOK Posted November 19, 2008 Share Posted November 19, 2008 GTR = number 1. covered many times, also have a look on Wiki. specs for the BNR32 & R33 (14411-24U00) T3 42.5 - 60.1 50T 0.42 T25 T25 41.5 - 50.5 62T 0.48 270° Ceramic ~225PS Link to comment https://www.sau.com.au/forums/topic/245491-gtr-twin-turbo-size-and-setup/#findComment-4271231 Share on other sites More sharing options...
.:: GimpS-R34 ::. Posted November 19, 2008 Share Posted November 19, 2008 ^^^ LOL what? i'm assuming you only read the title :S Link to comment https://www.sau.com.au/forums/topic/245491-gtr-twin-turbo-size-and-setup/#findComment-4272430 Share on other sites More sharing options...
SKY 34 Posted November 19, 2008 Author Share Posted November 19, 2008 You forgot the 4th option... two freakin' massive hairdryers producing loads of serious tire-shredding power! well, two large turbos will have running simultaneously will have the same setup as option 1. there are only 3 set up I'm quite sure Link to comment https://www.sau.com.au/forums/topic/245491-gtr-twin-turbo-size-and-setup/#findComment-4272640 Share on other sites More sharing options...
Beer Baron Posted November 20, 2008 Share Posted November 20, 2008 there is no such thing as option 2 mate. you cannot have 2 turbos running at different boost. there are 2 types of twin turbo set-ups. sequential parallel sequential set-ups have one small turbo and one larger turbo. the small turbo spools first and once the larger turbo is in it's efficiencey range it comes into play. these set-ups are quite complex and require some tricky valves etc to operate properly. My FD RX-7 has this set-up. when done properly they are quite good. the RX-7 pulls strongly from 2,000rpm, then it starts to taper off at 4500rpm as the small turbo is running out of puff, then at 5,000rpm the big turbo kicks in pulling hard to redline. parallel set-ups use two equally sized turbos running together. they both run the same boost level. this is the GTR type set-up. Link to comment https://www.sau.com.au/forums/topic/245491-gtr-twin-turbo-size-and-setup/#findComment-4272709 Share on other sites More sharing options...
