It just occured to me the other night that i noticed the seatbelt icon on my dash(little dude with the seatbelt-on sign) doesn't come on anymore...
cos normally when the driver's side seatbelts aren't buckled in the icon will light up etc etc....now nothing at all....
Anyone had this happen to them? Any ideas what's going on?
thanks;)
https://www.sau.com.au/forums/topic/24551-seatbelt-icon-disappears/
Originally posted by skyliner33wa
i thought that the seatbelt fastened feature was removed and seatbelts replaced during compliance?
Kris
No only the rear belts are changed. Front ones are factory. Yea check the electrical connection under the seat and then the bulb in the Dash. If that doesn't fix it,,,give up it's not worth working out.
Neil.
Neil.
Pretty sure mine has been changed then, i have had 2 skylines and both times no seatbelt light, are their supposed to be wires, or a connector coming from the seatbelt?
cheers
kris
i want the light!! you guys reckon there would be a way to hook it up?
has anyone check their belts with those from a wreckers without change made!! see if those plugs do actually plug into the clips?
I want the factory seatbelts! :) Well at least for the front, who cares about the rear passengers :)
Incidentally, even though my car was registered as a 4 seater, the compliancers nicely left the middle factory seatbelt in place, but under the seat. The previous owner probably didn't even know they were there :)
Does anyone know if the S14/15 200SX front seatbelts are the same as the R33's? It might be a good way to get some nicer seatbelts legally. Ones that use the seatbelt light, retract properly, and have that plastic thing to hold the belt off your shoulder.
Sorry guy's I should have worded my reponse a little better,,,,what I meant to say is the Fronts have to be changed as well,,,but It's quite legal for the Compliancer to buy New Factory Belts and install them. Thats how most of us still have the light working on the dash. Go check the white tag on your front belts,,,,Mine has Genuine Nissan belts with a built date on it,,being 2001.
Neil.
Originally posted by JimX
Ndr, how much are the new belts worth? Probably several hundred each ;)
JimX,,,I have no idea but mine have 2001 stamped on them and they have to be factory belts,,,.I'm thinking though if the tongue of the actual belt is the same as the buckles (this is what turns the light on and off) then you would only need to buy the buckle. Why not pop out to Justjap and ask them,,,,they might/should have buckles,,,you could try one.
Neil.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
