AeroGrace Posted September 10, 2003 Share Posted September 10, 2003 On my dad's gtst, we have a turbo-timer that has an inbuilt volt-meter that is preset to warn in below 11volts or over 15 volts. then recently on starting up, the volt indicator would go up to very high limits of 14volts.....any press on the throttle would result it going up even further up into the 15 volt limit. And it'll just stay around 15.2-15.7volts throughout the trip. Is the batterty overcharging for some reason? Or is the alternator rooted? All other instruments seem to work fine...although the only other thing i noticed was the headlights sometime seem to flicker slightly on startup. Hope i made sense. Anybody has experienced this? thanks:) Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/ Share on other sites More sharing options...
Neil Posted September 10, 2003 Share Posted September 10, 2003 Sounds like it might be the Alternators Voltage regulator or it's doide pack,,,off to the Auto Elect for you. Neil. Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-523485 Share on other sites More sharing options...
Craved Posted September 10, 2003 Share Posted September 10, 2003 OR try double checking with a multimeter on the battery, incase the guage is faulty... might save you money!! Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-524014 Share on other sites More sharing options...
JimX Posted September 11, 2003 Share Posted September 11, 2003 Yeah first thing to do is test it in your driveway (revving engine) with an accurate multimeter. If the voltage is definitely over 14.5V or so then get the regulator fixed asap! Seriously, you will start to blow your car's electronic stuff up if you let it stay over 15V. I know someone who had an old Magna that was running on about 16V and one by one his gauges started dying, and then his CD player. A new regulator should be around $100 or so. A nice auto electrician will replace it for you for free (should be a 5 minute job). Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-524232 Share on other sites More sharing options...
camandcandice Posted September 11, 2003 Share Posted September 11, 2003 hey i had this problem couple of months ago. Check your fuses in the boot, i had been playing around with those fuses and put one back in the wrong place causing my battery to overcharge like you have described. Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-524637 Share on other sites More sharing options...
AeroGrace Posted September 11, 2003 Author Share Posted September 11, 2003 .....thanks for all the input guys. time for me to look for an auto-electrician... Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-524722 Share on other sites More sharing options...
camandcandice Posted September 11, 2003 Share Posted September 11, 2003 check your fuses first dude it will save you money. As the ALT-S fuse often blows. The ALT-S fuse controls the alternator telling it when to charge the battery and at what volt, when this fuse blows or incorrectly placed the alternator continuously charges the battery flat out, compare the fuse layout to the cover Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-524868 Share on other sites More sharing options...
camandcandice Posted September 11, 2003 Share Posted September 11, 2003 ALT-S = alternator sensing switch Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-524871 Share on other sites More sharing options...
AeroGrace Posted September 11, 2003 Author Share Posted September 11, 2003 i hope it's that...might save me some money Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-524886 Share on other sites More sharing options...
Neil Posted September 11, 2003 Share Posted September 11, 2003 Originally posted by camandcandice ALT-S = alternator sensing switch Great Info buddy,,,,that's one for my little black book,,,,learn something everyday. Neil. Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-524937 Share on other sites More sharing options...
wrxhoon Posted September 11, 2003 Share Posted September 11, 2003 the voltage reg is built in the alternator , an auto electrician will usualy sell u a reco alternator regardles were u have a crook reg or alt . the diodes in the alt maybe the prob or volt reg . go to an auto electrician and he will check it for u , u may have a crook multimeter , one way to find out check the voltage on the battery engine not running then check again engine running notice the diff it should be 1/2 to 1 volt if battery is fully charged Link to comment https://www.sau.com.au/forums/topic/24553-voltmeter-goes-past-15volts-battery-overcharging/#findComment-525144 Share on other sites More sharing options...
