I remember reading on here somewhere and i have done searches but can't find what i'm looking for. I have the regency defect and my rego has expired. As we know you can't register a defected car. However, if you have the defect signed off and a regency appointment you can drive untill that date, the standard procedure when the car has rego.
I thought I read, that if you go to the regency park office with the paperwork they can issue you with some type of rego so the car can be driven.
I have the defect paperwork and has been signed off in the past. I have made several calls and been told that this isn't the case. Can anyone help??
https://www.sau.com.au/forums/topic/245579-regency-related/
yes you can, but it is classed as a permit rego
once ur car is cleared u take the reciept saying u passed regency and the reciept saying u paid 180 or whatever u paid for ur rego to the desk and they make up a sticker for you no questions asked,
can be tricky if you not sure wat to do or u get sum1 that doesnt know wat there doin at the desk
i only did this like two months ago, so yes it can be done.....
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4272153
so is your defect signed off and cleared or you going to regency? :P
why would you have an appointment to go to regency if its signed off and cleared already?
my rego run out while on defect and i had to buy stupid day passes each time i went to a workshop with it.
Edited by Inline 6
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4272276
yea trader plates im pretty sure work, but who the hell gonna lend you those
I got some when i took my skyline to the compliance workshop a couple weeks ago, just need to know the right people (Car dealers) lol
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4272810
$48 day pass.
any rego place.
tip: get the paper work first and fill it out. dont go line up for 23423 hours talk then line up again .
need to be really precise with where you are taking the car also.
workshop etc. regency etc. what roads.
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4273842
I had an appointment and was signed off at the cop shop but had an accident a week later and now have only got the car back from the panel beater. I don't want a day pass but be able to drive around untill my new appointment date.
so is your defect signed off and cleared or you going to regency? :blink:
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4274278
On my way to Regency. I had an appointment and was signed off at the cop shop but had an accident a week later and now have only got the car back from the panel beater. I don't want a day pass but be able to drive around untill my new appointment date.
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4274283
Yeah, not 100% sure on this but if they find out the trader plates don't actually belong to you or you aren't a part of the company you can get into serious trouble
Not ture customers use trader plates all the time for test drives, I would have said im taking it for a test drive and said the car yard i used.
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4276266
ok then. say your double defected (didnt pass first time regency)
can you still go to the cop shop and have your stuff ticked off (strut braces. suspension etc)?
then get your car rego'd till your inspection ?
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4279660
You need proof that you've fixed/repaired/replaced the items in question on the defect.
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4281832
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
