I remember reading on here somewhere and i have done searches but can't find what i'm looking for. I have the regency defect and my rego has expired. As we know you can't register a defected car. However, if you have the defect signed off and a regency appointment you can drive untill that date, the standard procedure when the car has rego.
I thought I read, that if you go to the regency park office with the paperwork they can issue you with some type of rego so the car can be driven.
I have the defect paperwork and has been signed off in the past. I have made several calls and been told that this isn't the case. Can anyone help??
https://www.sau.com.au/forums/topic/245579-regency-related/
yes you can, but it is classed as a permit rego
once ur car is cleared u take the reciept saying u passed regency and the reciept saying u paid 180 or whatever u paid for ur rego to the desk and they make up a sticker for you no questions asked,
can be tricky if you not sure wat to do or u get sum1 that doesnt know wat there doin at the desk
i only did this like two months ago, so yes it can be done.....
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4272153
so is your defect signed off and cleared or you going to regency? :P
why would you have an appointment to go to regency if its signed off and cleared already?
my rego run out while on defect and i had to buy stupid day passes each time i went to a workshop with it.
Edited by Inline 6
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4272276
yea trader plates im pretty sure work, but who the hell gonna lend you those
I got some when i took my skyline to the compliance workshop a couple weeks ago, just need to know the right people (Car dealers) lol
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4272810
$48 day pass.
any rego place.
tip: get the paper work first and fill it out. dont go line up for 23423 hours talk then line up again .
need to be really precise with where you are taking the car also.
workshop etc. regency etc. what roads.
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4273842
I had an appointment and was signed off at the cop shop but had an accident a week later and now have only got the car back from the panel beater. I don't want a day pass but be able to drive around untill my new appointment date.
so is your defect signed off and cleared or you going to regency? :blink:
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4274278
On my way to Regency. I had an appointment and was signed off at the cop shop but had an accident a week later and now have only got the car back from the panel beater. I don't want a day pass but be able to drive around untill my new appointment date.
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4274283
Yeah, not 100% sure on this but if they find out the trader plates don't actually belong to you or you aren't a part of the company you can get into serious trouble
Not ture customers use trader plates all the time for test drives, I would have said im taking it for a test drive and said the car yard i used.
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4276266
ok then. say your double defected (didnt pass first time regency)
can you still go to the cop shop and have your stuff ticked off (strut braces. suspension etc)?
then get your car rego'd till your inspection ?
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4279660
You need proof that you've fixed/repaired/replaced the items in question on the defect.
https://www.sau.com.au/forums/topic/245579-regency-related/#findComment-4281832
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
