MY ABS Story, 1997 R33 Gts-T: (skip to see resolution)
Over the past few months my ABS warning light has been on, no big deal, breaks still worked fine and it somehow it passed NSW roadworthy. But I wanted to know what the problem was and I didn't want to spend $250 on a replacement ABS unit.
I had the car data streamed and It responded with "ABS motor [off] or fail" no real help.
My Issues started about 6 months ago where the ABS motor would not switch off, it continued running even when the car was completely off. I figured faulty wiring or faulty abs module, and just unplugged it.
I downloaded the R33 workshop manual and traced through all the wiring, fuses and relays*
I found two 30amp SPDT (single poll double throw) Relays in a module attached to the abs pump
Part Number:47605
Long Story Short, I tested the Relays one would Close Circuit when powered, the other one would not.
I cut the faulty Relay apart and found the small connection point broken off, I re-applied the contact and put everything back together, All worked 100%. I will buy a new relay and replace the old one. The original Relay was matshita, but it can be replaced with a Panasonic.
For a $4 part the problem is solved. This is definitely worth checking.
Pic 1 Original Relay
Pic 2 Relay Internals
Pic 3 R33 Spares
https://www.sau.com.au/forums/topic/245611-r33-abs-problem-fixed-for-4/
  • 1 year later...
hey guys,
this problem just happened to me a couple of days back. after a good thorough wash, this stupid ABS light comes up whenever i start moving my car. at first it was intermittent but now, it became permanent.
i have decided to do the following checks before bringing down to a mechanic.
1. check, clean sensors
2. pull out the relay
however, i am not really sure which the sensors and the relay are. it will be great if someone can help me out with this.. pics do a thousand words =)
Hey has anyone got any pics of this relay? as I have an 96 GTST with the ABS light on and its realy starting to piss me off?
I know its an old thread but surely someone out there would of done this check surely??
Regards,
Draren
  • 3 months later...
Sorry for digging this thread out of the grave, but my car has just failed the e-Safety check due to the ABS light showing!
I'm about to ring an auto-electrician to see what he can do. I would have had a crack at it myself but am at work and need to leave for Melbourne on Thurs (it's Monday today), so don't have time.
Will let you guys know if it works!
  • 1 month later...
Sorry, forgot to follow up on this... yep, basically I just replaced the whole box that contains the 2 relays. Took me 5 mins to replace and worked like a charm straight away! Only downside: cost me $75 and the guy tried to charge me $100. I think I got ripped off? Nevertheless, I had to buy it on the spot as I really needed the car registered quickly and didn't have time to play around taking the relay box apart and waiting for relays to arrive from overseas :)
Was also thankful that it wasn't the ABS pump - the parts guy said it would have been about $250-300. Also think that's a bit steep?
Edited by benro2
  • 9 months later...
  • 1 month later...
  • 3 months later...
I ended up just buying another block relay, was impossible for me to desolder the pins off the relay as I don't have a proper desoldering tool (with built in vacuum) using a hand vacuum pump and a decent side soldering iron, I still couldn't remove all the pins.
Probably easier if you brought the relay to an electronics guy and ask him to desolder & resolder the relays on. Relays can be bought from Jaycar.
I'll take photos of the horrid mess I made tonight LOL
  • 6 months later...
remove the relay block (1x 8mm bolt) and unplug all the connectors... give it a hard shake, it is sounds loose I'm sure it is dead.
I actually threw mine in the bin so I can't take photos of it.. but if you crack open the housing there are 2x pcb flush mounted relays.. I tried to desolder them but don't have a proper vacuum desoldering iron. Ended up melting half the PCB so I gave up. A hand desoldering pump won't do it, as the relays are flush mounted.
Went to a wrecking yard and paid $50 for an entire ABS unit and block relay. Tested on the spot, worked done :)
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
