Driver Dynamics Beginners Drift Day Sandown Saturday 17th January 2009
Hi I have just moved over from Ireland and want to know will my full Irish licence will do I also have an international licence
thanks
Des
Des, your license is fine, no problems.
Jack- Posted Today, 06:29 PM
Do we have to book, if so by when? Might see if a few of my mates are interested and get them to come down aswell.
Jack, you'll need to book in pretty quick, we're almost booked out, call the office 1300 652 693
Italiazr1 Posted Today, 05:31 PM
Kev
i rang up today bout it all apparently they split the track up into 3 sections where its safe to "drift"
should be an awsome day there is only 10 spots left too so be quick i am penciled in for the day and i can pay for it in the near future....
haha must be cause i sweet talked the sexy voiced girl on the phone
We'll be running at 5 different areas on the circuit, we are nearly booked out, I'm sure Andre - Brittany - Sarah couldn't resist your charms, all the Driver Dynamics office chicks are super hot !!
  • Replies 147
Posted Images
stupid n/a diffs.. will there be any water on track or just dry? prob a waste of time for me if its dry unless i get a new diff lol.
i guess i could weld it lol.
The exercises will be conducted on wet roads to keep the speeds down and minimize wear and tear on your car.
Also tyres need to be inflated to at least 40 psi so you should be fine.
:P love my weldy...first thing I did to the car...and probably the best haha
Till you start twisting/poping drive shafts or breaking bushes, etc. :)
Mechanical LSD FTW!! :D
Yeah everyone keeps saying that. But i have spares just in case....LOL! Been close to 2 years now.
you guys think there will be an issue with oil to the engine as the car is being thrown sideways on high revs? Or are we all weak beginners that we cant throw it around hard enough to starve the engine of oil?
Do you think they will take video footage?
i really wanna see what it all looks like later on.
Im happy to pay for a video later or something it would just suck if we couldnt
that why i was going to bring a friend or two?
but yeah got comfimation and it says no spectators...?
A camera in the car just doesnt cut it for drifting....
If all the spots are booked out can we go watch and check it out?
Just to answer a few questions..
Sorry but there will be no SPECTATORS. So dont just turn up on the day. You wont get in.
And Yes the track will be wet. So your NA will be fine.
I dont belive the office girls will be there on the day.
Cheers..Wayne
Guest
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
