IMO
just let ur car warm up. thats all I do. and havnt had a problem yet. (touch wood), i think you would only need this in really cold climates. also comes down to the type of oil you are using, and i would imagine you would be using some full or semi synthetic type of oil so you should be ok.
my recommendations for track work or at least your first outing
- turn the boost down, turn it down a few PSI - youll still make tons of power
- watch oil temp & water temp (Get a warning light for these)
- watch knock - make sure engine check lamp works and your knocking warning is turned on
- run 100 ron if you can as insurance policy
- check tyres, pads and rotors before track day
- if your running semi comp rubber get some advice before using them
- oil cooler is critical
-- dont get a cheap junker kit, get a trusted japanese brand kit to suit ECR33
-- this will ensure correct fittings, right hoses etc
-- any failure / risk in the oil system puts the engine at great risk
heat will be your biggest problem. heat in the pads, rotors, calipers, turbo housing, dump pipe etc
thanx paul, i'm putting on a trusted kit fer sure, i dont run any cheap parts on my car :yes:
boost is always on my actuator's minimum for extended thrashings... (1 bar)
oil is slightly overfilled
everything else is always checked :P
Don't worry about your oil temps around the streets not getting hot enough quick enough.
use good quality oil and that's all that's required. There are HEAPS of us getting around with oil coolers and no thermostats.
The highest wear and tear time on an engine is at initial start us, for those first few seconds before oil pressure is 100%, and there's nothing a thermostat can do for that.
for an update im also drilling a custom oil return from the head to the sump :P
if i go for a thicker head gasket to lower compression, how much power can i pick up up top vs losing response?
the car is already very responsive (full boost of 20psi by 3500) so i do have a little can afford to lose i spose...
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
