lookin 4 gtr info
stooj
 Share
  • Replies 41
Stooj,
Depends on what you are after. 32's go for as little as $27k, but for a decent one you'll be wanting to spend over 30k. 33's again as little as say $40k but $50 and up will give you a low km later model.. Obviously there will be exceptions and mods can either bump or drop the price depending..
What model are you chasing and what is your budget would be the best place to start.
Cheers
Brett
Real GT-R will have the wider front and rear guards, will have full attessa 4wd system and of course the engine will be an RB26DETT. As for differences between V-spec and non V-spec - on an R33, you'll find a finned diff cover on the V-spec and smooth dome diff cover on the standard edition. For 50K you should be able to find yourself a fairly good condition GT-R. Buy as late model as you can afford too. And make sure you've got insurance lined up before hand too cause if using bank for funds, they'll need to know it's covered. For insurance, you could try the main ones, but wouldn't waste your time. Call Famous Insurance or Silvalake (they're both brokers). Both do imports and I currently have both the GT-R and Silvia insured through Silvalake.
Cheers
Brendan
50k will get you a decent 33 or a monster 32 depending on what you want...
Fake Gtr's are hard to make and would be expensive anyway so unless someone tries to sell you a gtst as a gtr it shouldn't happen. Vspec in the 32's had brembo brakes, different wheels and stiffer suspension I believe, in the 33's an active LSD, stiffer suspension was about it.
All GTR's have Attessa (Vspecs have Attessa-PRO) which transfers the torque to the front when the rears lose traction if thats what you were asking about..
If you ever come down to Perth let us know and we can show you some of our cars...
Cheers
Brett
Stooj,
My 95 GTR Vspec cost $49k a year ago so yeah that price will probably get you a 97 now.. Just get a decent workshop to go over it BEFORE you sign anything. If the car yard / private seller won't let that happen walk away even if you love the car...
Brett
Insurance for my GT-R at the moment comes in at about $880 but could be wrong. For my previous R32 GT-R V-spec, it was insured for about $46,000 and insurance was ~$1,700/yr. My current R32 GT-R is only insured for $26,000.
real sensible thinking there for a 17 year old... "i gotta job lined up moite!" owning a car and maintaing/running a car is a whole different ball game... which hopefully you see, before you piss your inheritance away on a car....
i see ur point there man , im not gonna get this car straight away though im talkin 1-2 years time, maybe 3-4 depending on money,
but im not a dickhead on the road , ive seen what happens 2 people that r uncle in victoria was killed when the car smashed through a house, my mate rolled his car doin snakies.... dont wanna go there
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
