Now dismantling r33 s1 coupe
In good condition
Melborne
Left front Guard $80
Right front guard $80
Left door (passenger) $120
right door (drivers) $120
bonnet $150
Front Bar $150
Rear bar $120
front seats (pair) $200
Headlights (pair) silver lined $200
back seat $120
5 stud conversion parts Callipers hubs and rotors. $1100
+ many more
please contact me at [email protected]
Guys i do have these parts im just waiting to hear back from someone who is thinking of taking the whole car
but he didnt sound too keen so heres pics anyway
will get you prices if i dont hear from him in next couple hours.
post-13428-1227251039_thumb.jpg heres the car incase anyone wants to see pic
post-13428-1227251372_thumb.jpgthis is faded at one end and has some scratches
will be back around 8 and will let you know if they are available
Edited by r33rckt
hey mate,
after a few interior pieces.
- centre console cup/coin holder with power/eco switch
- passenger grab handle
- passenger a pillar trim
pm me your number and some prices if u got the bits. as long as they as the same color as my series 2 i'll take them..
hi mate im after the power steering computer/hicas computer that mounts under the parcel shelf on the right hand side.
let me know cheers
still plenty more parts keep the requests comming.
PS Anyone ive given my mobile number to if you dont get through do leave a msg
somtimes it works somtimes it doesnt
(my girlfriend put it my jumper in the clothes dryer and it was in the pocket.. DOH!)
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
