Not sure yet.
I have to save the funds to buy what looks like ALOT of cam gears judging by the response from this thread.
Or i can start taking payments from people which means some people will be waiting a long time.
Not sure how to go about it.
At the moment im just saving the cash to buy all of them myself.
  • Replies 62
Posted Images
i got the money right now.
you can start to collect these guys, i have n probs with it.
the faster the better.
Nytsky pls PM me the details.
cheers mate.
Dave ill take a set when you get them. RB26 of course. Ill send you the money over the next few weeks to take the stress off your bank account
EDIT: Actually, 2 sets thanks.
so ur gonna bulk buy them yourself, then ship them to everyone at the same time? im still aquiring a few other things (timing belt etc) to put in with my cams so not in a hurry at the moment, but yeah even if you could pm a rough date that would be appreciated.
cheers mate.
Got some bad news guys.
The supplier was claiming they produced Tomei cam gears. But when i placed the order they then told me they were copies, hence the cheap price.
However i have been assured that the cam gears are made form the same material and anodised the same so the quality is still very good.
Two of my friends have these same cam gears in their GTRs and have produced the same gains and would not have picked them to be copies.
They also produce about 80% of all the other cam gears on the market and have had not one failure.
At the end of the day there is no real difference or any more gains to be had out of the Tomei versions anyway.
If you are still keen on them let me know and ill revise the order.
Im still ordering ones for mine and other friends vehicles.
CHEERS
The pic that was supplied. The cam gear was red, grey teeth and no logo.
However the design of the actual gear looks the same.
I have been told if i send them a sample they will match it. I just dont know the legality side of copying a name brand logo.
Either way im going to order 20 sets for a group buy. They will perform the same as any other cam gear out there so im not worried.
Half the price of a genuine item :(
ive got a set of genuines in the box here...ill get Dave to make Tomei decals up for your by copying them.
Edited by DiRTgarage
  • 1 month later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
