hey guys,
my headlights on my 33 are bugging me.
the LHS beam is at a normalish sorta angle
but the Drivers side is pointing significantly higher and blinding other drivers i assume =/
both high beams seem to be at a good angle...
its just the Drivers side normal beam that points higher...
what can be done about this ?
thanks in advance :blink:
https://www.sau.com.au/forums/topic/245755-r33-s2-headlights/
Try adjusting the headlight..
You should see two screws - one at the top and one down the bottom somewhere i think..
Point the car towards a wall (do it at night time)
Here is a picture i took when i installed my HIDS..
So anyways.. When you adjust it, you will see the beam move up and down or side to side..
Left hand side should be easy to adjust.. If you got a airbox on the right hand you might have to take it out.. To get to the screws..
If i still had my car i would have taken some pics for you..
Edited by siddr20
