Hey, i'm on my P plates so i don't want my car decked out with a heap of mods. I just want to know whats the best part to put in my car to make it go faster. I want the best results though, i don't want a part thats not going to do barely anything. I want to be able to notice the improvement in power.
My friend had a Celica that at like 4,000 rpm's in 3rd gear it just seemed to boost forward a fair bit and he said it did the same in 5th gear. He said it had to do with the fuel injectors but he knows nothing about cars so 99% chance hes probably wrong. His was non turbo etc so yeah if theres a part that can make that happen then i want it lol.
So far i just have an exhaust system.
Also please don't spam my thread with "your on your Ps, you aren't allowed modifications" or "your not a skilled enough driver, just get handling mods like braking and suspension". I know a ton of people on the forum that have illegal mods, so by me modding my car its no different to everyone else with their illegal mods. Also i'm not going to be a dickhead in it so i don't need handling etc, i just want a bit more power.
I reckon the only single part that would mean instant gains would be a turbo, so thats out of the picture aye..
Like me your on your P's.. so i guess the only way your gonna' get noticable gains is with a few mods that compliment each other.
Pod Filter, enclosed..
Cold air intake.
Exhaust ( you already have one, but how big is it ? )
If you want more information dude, theres a sticky by EUG that goes into great detail, you just pick and choose what mods you want..
and just in case you want a lil sneak peak heres a lil peice from his write up..
" How to get more power from a naturally aspirated engine?
There are many ways to get more power; it all comes down to budget and application.
Power is defined by the rate at which work is performed over a unit of time. Used in our context, power will represent the maximum kilowatts (kW) a vehicle produces as measured on the dyno. However, the key factor in the above equation to take into consideration here is 'time', which is essential for 'response'.
Being a naturally aspirated, the motor is neither turbocharged nor supercharged. This means that the motor relies on vacuum created by the cylinders and natural atmospheric pressures to draw in ambient air for combustion.
In order to get more power you will have to rely on the basic principal of: letting the motor breath/work better, so to speak. This is done by removing the restrictions within the system and thus creating more efficiency.
Here is a basic list of what can be done, we shall elaborate on them at a later stage:
Intake (pod filter, panel filter, larger throttle body, cold air feed)
Neat Cold Air Intake
Professional Looking Heatshield
Exhaust (extractors, cat converter, cat back exhaust) "
Head over here .
http://www.skylinesaustralia.com/forums/Po...sp-t194033.html
Have fun man!
MRXTCZ
thanks for the reference vik.
have a good read of that thread tyson. there is no ONE PART to enhance performance.
handling mods will make you go faster, it just seems like you are chasing a number.
i'll be keeping an eye on this thread.
I think the most important question you should be asking yourself is "how much am I prepared to spend?"
In terms of an NA car you need to spend some money to net a half decent gain.
You need to focus how well the air flows in and out of an NA engine.
The best gains to to be had are in cams. Have a look around the net for a set of aftermarket camshafts ($600 odd new). To get the best gains you'll also need a pair of adjustable cam gears for both the inlet and exhaust camshaft ($300 odd a pair new). Do you have a S1 or S2 R33? I can't tell from the pic. Because whether or not you have an NVCS will also influence cam gear choices. The final item to tie it all together and tune the engine is some form of engine management. Now, personally I cannot justify an entirely new ECU system for the 20-25odd KW gain your going to be getting. A simple Apexi SAFC to tune and set the engines increased demand for fuel will suit without a problem. Once all this is done, an upgrade in fuel pump is proprably a good idea too as the demans placed up the OEM pump are significantly increased and the unit is probably getting warn down after 15odd years of use and abuse - DET is cheap, easily found and is more than enough for your application. If you get this far, have a chat to your tuner as the injectors may be starting to struggle at this point too. $100 odd and you got yourself a set of second had RB25DET injectors. Cheap upgrade.
Its a relatively cheap set of modifications you can perform to gain a half decent power figure. Even with jsut 125kw your increasing engine performance by 25% which is a fair whack.
Its a place to start. From here on in things get expensive. Your looking at taking the head off, porting, polishing, increasing engine CC's, compression ratio's etc. and its bloody expensive.
It's a shame my sig is currently full of comedy gold. If it wasn't, this would have just made it.
If you wanted power without control, you should have bought a Falcodore. There's a modification for you.
Edited by scathing
i agree with Alan (scathing) that has to be up there with the stupidest comments i've ever heard.
if you want to go fast legally, improve your driver skill. i can match some gtst (and a few gtr) times around QR with purely suspension work and a bit of practice.
typical 17yr old? gives the rest of us a bad name. The power leads to handling problems, yea you might not plan on being a dickhead all the time, but what about the occasional time?
And didnt Hot4s shave a couple second off their track time in the Evo with just a wheel upgrade?
Anyway off topic, depending on how much money you have will depend on the power upgrade. NA motors are a system, to get the best out of it, the whole system needs to be upgraded. Exhaust, Cams, Injectors, etc, you will feel and hear a change for a while, but soon after, you will get used to it and want more. Keep that in mind Champ.
If i were to mod my NA there would only be a few things i would consider doing to my engine. That would be a full exhaust and a decent CAI. Anything more and you will be spending a lot of cash for little gain.
IMO if its accelaration you are after you are better off looking into other areas of your car. I would be changing my diff gears to the possible shortest ratio (I believe gts4 diffs are shorter than the rest) And using tyres of the smallest rolling diameter that you are legally allowed to run...
"I know a ton of people on the forum that have illegal mods, so by me modding my car its no different to everyone else with their illegal mods. Also i'm not going to be a dickhead in it so i don't need handling etc, i just want a bit more power"
keep up with that attitude my friend and you'll mod yerself right round the nearest tree and into the hospital.
I am from the good ole uk, so know very little of the legalities of the modding situation over there. modifing an NA (and keeping it na) isnt a one part fits all scenario..so have a shop around.
lightened flywheel - you will notice some difference
Shave the head a few thou to bump up the comp a little will help also
lower diff ratio has always been my favourite mod for gains
Cold air/ RAM air intake
Anything more than this and you start talking big work and big $
I would have recommended a bolt on Supercharger ( VT Commodore EAton M90 ) but that will need tune and many other mods so still wouldnt be cost efficient compared to a whole turbo motor swap
other than that a tune maybe ?
ok as every ones being saying exhasut, CAI, cams,.
ill give you my sotry.
R31 skyline RB30E
started with 70RWKW with only a 2.25' exhaust
after nistune ecu, custom crow cam, exstractors, k&n pod. all tuned i had 118.6RWKW.
cost of about $3500 due to getting some parts cheeper.
www.nistune.com to find out more only cost $250
Thanks, i don't really want to be spending a whole lot on my car since i mainly only want it till i'm on my opens or a year or two after so that i can then buy a turbo, hopefully a R34 GTR. What's an Apexi SAFC tune and how much does that cost? Also i think i see injectors being sold a fair bit on this site, you need like a set of 6 or something don't you? I always look at the parts for sale to try to learn more about what does what. Also what is a DET?
Thanks for all that, that doesn't look too expensive which is good. Oh and i have a Series 1 R33.
Thanks, whats a CAI? Also how would i change my diff gears and would making them shorter have any negative effects?
I've read the sticky regarding performance but didn't really understand everything thats all.
To all those saying i sound like a dickhead etc, i've already got good handling. I don't go fast around corners, i don't take my car to the track or anything. The only reason i want more power is just for accelerating basicly in a straight line. I'm not wanting more power so i can get out of corners real quick or anything since yeah that'd be stupid. Going in a straight line doesn't require the best of the best handling.
CAI = Cold air induction
The only negative affect you get from putting in shorter diff gears is that you car sits on a higher rpm at any given speed. It will really only make a difference to fuel economy if you spend a lot of time on the highway.
And it will only be worse on fuel on the highway. from my experience dropping diff ratios actually improved economy in normal stop start driving conditions. There are a lot of wives tales about dropping diff ratios usually told by know it all old guys... Crap such as " It will get off the mark faster but its got no top end acceleration " Well from my experience thats crap....You will feel gains at every speed.
As for having no top end ? I found that I had a lot more top end acceleration.I wouldnt worry too much about it revving harder as you got an overdrive gear already.. If it only revved 500 rpm harder on the freeway for the same given speed then thats quite acceptable. But the difference in acceleration you would be much happier with.. Go to a diff specialist and see what they quote you. Dont let some hack mechanic do it as if its not set up correctly you will have the annoying howl coming from it...not good
Also what is a DET?
DET is short for the RB25DET, which is what GTSts have. basically, you have a DE, non turbo, hence T stands for turbo :P
D= Dual Overhead Cams
E= EFI (Electronic Fuel Injection)
T= Turbo
and for the record, i think handling mods, even cheap ones like sway bars and strut braces, are a good investment no matter what power levels you have
Edited by G0DZLR
If your not planning to have it that long then I wouldnt even recommend doing too much to it.
instead of spending bout $1000-$1300 on cams and gears, use that on your next turbo car..(I picked these mods because u already have a full exhaust they are the next best thing to do for power)
also... people are probably going to have mixed opinions about what I say next, but I have read this in a few magazines about skylines....
went something along the lines of:
"Skylines are a supurb car to drive for performance and handling, however there are quicker cars that go in a straight line, but they are one of the toughest competitors around a track."
Not saying obveously you can make them go faster in a straight line, but it takes mods and money to do so... stuff that at the moment I imagine arent flying at you(im a p plater too)...
so definetly do try a cold air intake and a heatsheild, but you'll be spending a decent amount of money to notice any type of gains from an n/a...
one final thing... personally, I would recommend doing cam gears for now, I did it to my car last week and noticed a heap of difference in response and torque, which from the sounds of it, you are after aswell.
Adam
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
    • interesting....sounds like the later trans has software differences (or AM vs JDM). If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
