I would think they will stick out quite a bit. Probably best to get better offsets because dialing in negative camber will kill your tires a lot quicker.
If your car isn't lowered you wont have problems, except for scrubbing at the front, but when you want to lower it then you will have to do something more.
Comparing them to my current wheels, your fronts will stick out an extra 10mm. I'm running 235's on the fronts and have not rolled my guards, but scrub the liners under full lock, and just under full lock depending on how the car is sitting etc. I'll be rolling my front guards as if I was to hit a decent bump (or ripple strip on the track) with some lock on, they could hit the guards, so I'd suggest you doing the same (as well as removing guard liners).
Your rears are gonna extend outwards an extra 10mm over mine as well, and mine were protruding the guards by quite a bit...you'll definitely need a fair bit of flaring to get them to fit.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
