hey guys received my nismo 600cc injectors yesterday afternoon, i thought the nismo 600cc injectors have purple tops but my ones seem to have pink tops, now i messaged a forum member and he wreckens
555cc- pink tops
600cc- purple tops
now i bought these from an sau member GGG and he had them advertised as 600cc injectors, well he didnt have them advertised yet but offered in the WTB section to soemone else but seems like an honest guy,
can yous guys please help me with this just before i get them put in the gtr guys so i can give the previous owner a ring because i dont want to be scammed again because it will turn pretty ugly
thanks again guys
cheers tony
hope this helps
NISMO 555cc Injector (Pink) x 4
Nissan Pulser GTiR - RNN14 should be the same for GTR they use the same standard injectors
nismo 600cc purple
Edited by johnbarry88
yer i contacted who i bought them off today and yes i was told today that pink was 555cc and purple was 600cc so i am getting my money back and me sending the item back off, thanks guys
cheers tony
guys what do you think is better for my gtr, aiming for about 350kw and as i said i got these injectors which i thought were 600cc with the purple tops but they turned out to be the nismo 555cc, will these injectors be good enough for my sard 280 pump along with an adjustable nismo fuel reg, will they be good enough for that power range, because i dont want to really go through the hassle to return them back,
guys what do yous think of these nismo 555cc injectors, is there a big difference between these and the 600cc nismos, these retail to alomst $1200 these days so they arent cheap but thats not the Q, will these be good enough for my application
please guys can yous help me, i would really appreciate it
cheers tony
555's would be able to do 350kw. Wont be a lot of room but enough. Worse case up the rail pressure 2-3psi and it'll sort that out
hrmm, what do you mean by up the rail pressure 2-3psi?
are they a much difference then 600cc injectors?
i just spoke to a mate of mine barry form edge motor works who is local to me and helps me out, he said nismo 555cc would be perfect for around 330awkw or something, he sais the bigger injector you go the more juice i go thrugh, he said stick with nismo 555cc injectors and with a decent tune they will be perfect for that power figure im after, really only mods i want after this are the -5 turbos and the tomei 260 cams with around 18psi and ill stop until the car needs a rebuild
yous think it will be all good guys?
The 555cc Nismo's are the best injector for your application - they are by far the injector of choice, the sards are crap. Besides you only need about 8psi more base pressure to get you to th equivalent flow of a 600cc Inj.
they are a pretty good injector but man if i want to produce around the 350kw i dont really want to max these inj to their limits if you knwo what i mean, my aim is for around the 350kw mark, i better just send them back
thanks guys
cheers tony
guys called up ben at racepace yesterday in the morning and he said that the nismo 555cc injectors are good for 350-360kw, he goe it just depends on the tune so he said nismo 555cc are an excellent injector and perfect for your application so i guess i should listen to him and ill stick with the nismo 555s,
will get yous the dyno results after the car gets all done and tunes at racepace, before with the stock gtr pump, stock injectors it got 245awkw at prottek automotive at 1bar, now ive upgraded the pump to a sard 280, injectors are nismo 555cc and also have purchased a nismo fpr so will like to see the results, only thing that stuffs it all up is that it still has the stockturbos, but soon to be upgraded to gt28/60r -5 or -7, we will see what ben thinks
thanks for the help guys
cheers tony
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
