hey guys received my nismo 600cc injectors yesterday afternoon, i thought the nismo 600cc injectors have purple tops but my ones seem to have pink tops, now i messaged a forum member and he wreckens
555cc- pink tops
600cc- purple tops
now i bought these from an sau member GGG and he had them advertised as 600cc injectors, well he didnt have them advertised yet but offered in the WTB section to soemone else but seems like an honest guy,
can yous guys please help me with this just before i get them put in the gtr guys so i can give the previous owner a ring because i dont want to be scammed again because it will turn pretty ugly
thanks again guys
cheers tony
hope this helps
NISMO 555cc Injector (Pink) x 4
Nissan Pulser GTiR - RNN14 should be the same for GTR they use the same standard injectors
nismo 600cc purple
Edited by johnbarry88
yer i contacted who i bought them off today and yes i was told today that pink was 555cc and purple was 600cc so i am getting my money back and me sending the item back off, thanks guys
cheers tony
guys what do you think is better for my gtr, aiming for about 350kw and as i said i got these injectors which i thought were 600cc with the purple tops but they turned out to be the nismo 555cc, will these injectors be good enough for my sard 280 pump along with an adjustable nismo fuel reg, will they be good enough for that power range, because i dont want to really go through the hassle to return them back,
guys what do yous think of these nismo 555cc injectors, is there a big difference between these and the 600cc nismos, these retail to alomst $1200 these days so they arent cheap but thats not the Q, will these be good enough for my application
please guys can yous help me, i would really appreciate it
cheers tony
555's would be able to do 350kw. Wont be a lot of room but enough. Worse case up the rail pressure 2-3psi and it'll sort that out
hrmm, what do you mean by up the rail pressure 2-3psi?
are they a much difference then 600cc injectors?
i just spoke to a mate of mine barry form edge motor works who is local to me and helps me out, he said nismo 555cc would be perfect for around 330awkw or something, he sais the bigger injector you go the more juice i go thrugh, he said stick with nismo 555cc injectors and with a decent tune they will be perfect for that power figure im after, really only mods i want after this are the -5 turbos and the tomei 260 cams with around 18psi and ill stop until the car needs a rebuild
yous think it will be all good guys?
The 555cc Nismo's are the best injector for your application - they are by far the injector of choice, the sards are crap. Besides you only need about 8psi more base pressure to get you to th equivalent flow of a 600cc Inj.
they are a pretty good injector but man if i want to produce around the 350kw i dont really want to max these inj to their limits if you knwo what i mean, my aim is for around the 350kw mark, i better just send them back
thanks guys
cheers tony
guys called up ben at racepace yesterday in the morning and he said that the nismo 555cc injectors are good for 350-360kw, he goe it just depends on the tune so he said nismo 555cc are an excellent injector and perfect for your application so i guess i should listen to him and ill stick with the nismo 555s,
will get yous the dyno results after the car gets all done and tunes at racepace, before with the stock gtr pump, stock injectors it got 245awkw at prottek automotive at 1bar, now ive upgraded the pump to a sard 280, injectors are nismo 555cc and also have purchased a nismo fpr so will like to see the results, only thing that stuffs it all up is that it still has the stockturbos, but soon to be upgraded to gt28/60r -5 or -7, we will see what ben thinks
thanks for the help guys
cheers tony
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
