Offered up the rear Brembo callipers from an R33 to my R32 GT-R last night.
Problem being the hoses from the 33 are too short to connect properly. Also the hoses from the 32 have a different end connection (block mount) to the 33. So I cant just swap stuff over.
So the question is this:
Anyone that has done this conversion what did you use for hoses. I there a 32 Vspec hose package with a block end connection or are they all the same & connect striaght into the calliper? :D
Edited by djr81
https://www.sau.com.au/forums/topic/245783-r32-rear-brembo-issue/
Strange. I have aftermarket braided rear lines and they screwed into the GTR caliper no problem. So sinc emy aftermarket GTSt lines worked, i assume then the std GTSt lines would work. I would also expect that the GTR are the same as well. I did modify the bracket that they all mount to the caliper like the R33 lines do, but i wasnt supplied any of the std R33 lines so just made my GTSt ones fit
So the lines you have go straight into the calliper? No stuffing about with blocks & hard piping?
The line would fit but the 33 is approx 30mm shorter than what it needs to be.
As an aside the bolts that attach the rear Brembos are M10x30 with a 1.5mm pitch.
The bolts that attach the rear Sumitomo's are M10x30 with a 1.25mm pitch.
You have to go to a proper bolt shop as the Champion packs you find at most auto parts shops start at M10x35.
Photos:
Brembo first.
Sumitomo second.
Edited by djr81
Have pretty much done the same. Sent the old rubber hose off to Perth Brake Parts with an instruction to make it the same, just 30mm longer.
As an aside (another one) the pads I got for the F40 callipers are listed as "BA Falcon Fronts from the 4 pot calliper" - presumably a Brembo item aswell. They have what I took to be a slot for a pad wear indicator. Is there another common car that uses a similar pad but minus the slot for the indicator?
Edited by djr81
the problem is with your front callipers. they are no good. send them, and the calliper mounts to me and I will dispose of them safely for you mate. wouldn't want anything bad to happen to you. I care.
Thanks mate. :O Do you need me to cover you for any expenses or will a carton of Crownies surfice?
I asked the nice folk at Racer Industries what a 345x32 2 part front rotor was worth. Answer:$1k. Per side. Ow, ow, ow. So am staying with 324's for a long, long time....
Edited by djr81
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
    • Which one did you buy? I have always wanted a decent inspection camera but have been unable to tell whether something is cheap junk or cheap junk chunk sold at just a bigger markup
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
