Hi Guys
Ive got a series '1.5' R33 (S1 engine) that about 6 months ago started having a missfire about 1% of the time and I would pull over and restart the car and it would fix it self.
Because it was so intermittent it took ages to get it to my mechanic while it was happening. I finally got it there while it was missfiring and he replaced the sparkplugs.
Didnt fix it and its slowly started happening more of the time until a few weeks ago its happening around half the time its going.
Took it back to my mechanic and he said coilpacks, so now its got splitfire coilpacks in it.
Didnt fix it.
To be fair I live in a country town and im fairly certain my car is the only skyline the mechanic works on.
Anyway i took a short 16 second vid, while you accelerate the engine it has an exhaust sound like a wrx instead of the normal smooth sound.
http://au.youtube.com/watch?v=hV68RI5Zhmw
(how do you embed the video here ?)
Thanks for any advice.
btw, its got a front mount, pfc, elec boost control, some other stuff and around 200kw.
I'd look at all the small things first before spending any more $$$, wiring, fuses, earth straps, coil loom, fuel pump wiring and fuel pressure, 0.8mm spark plug gap, clean AFM, O2 sensor, injector clean etc etc etc These things can drive you bats finding them.
Also try this: http://www.skylinesaustralia.com/forums/St...er-t233110.html
Get a screw driver preferably one with a steel shaft all the way through and start your car. Then use the screw driver as a stethoscope and put the blade end on the top of the injector and use your hand as a cup and listen to the noise coming out the end of the screw driver. Make sure that all your injectors are making the same level and pitch of click, ( if you know what i mean).
This will be very hard if you don't have a forward facing plenum, got GL anyways.
ohhh no a missfire ?? was anybody hurt?
Only my pride and bank account so far
loose injector plug? or perhaps faulty injector?
Ill get him to check injectors
Thanks
Did mechanic regap your sparkplugs? After I installed my new sparkplugs I had all sorts of misses, after making sparkplug gap smaller the missfire was gone.
Something to try anyways, GL!
Ill ask
Thanks
I will suggest these things aswell
and thanks for the link, fingers crossed its something simple like that !
Thanks
Thats way to complicated for me :down:
Ill suggest that method to my mechanic.
Thanks
sounds like problem with one or two of your injectors. does it drive like a WRX? joking does it drive like a dog is there a noticeable loss of power ?
Huge loss in power when it happens, so yes just like a wrx :)
Thanks for the tips guys.
  • 6 months later...
sorry to drag up an old thread but im selling this car now and it reminded me that I never posted up what fixed the missfire. I dont want people searching my posts and thinking it isnt fixed !
anyway it was a dry solder joint in the electrics.
1000 points to tridentt150v
    • -9s are discontinued supposedly. But you can still get Nismo R3 turbos which are something like a -7 but subtly different? -7s are also available. HKS GTIII-SS and GTIII-2530 are also available but they're journal bearing MHI turbos.
    • Late to this party but here is your go to shop in perth - https://www.facebook.com/gsautoworksau GTSBOY is on the money cost wise, drive in and out will cost you 15-30k or more.    Some items that will save you money  - plug in link ecu g4x is much cheaper than haltech.   -Pulsar turbo, seem to be "OK" now, never used one myself You really don't have to build the motor, E85, headgasket, studs and a good RB26 will live for ever.    Swapping over the twins won't save much as you still need ecu, tune, fuel system etc.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
