Nice as the Nismo ones are, they aren't what I'd call flares, they're just body mouldings. I think the OP actually wants more track, which they'd be useless for.
Love the car in the original post, flares or not, silver BNR33 with white rims is an epic win.
Those flairs on the original post are just beautiful. Would add immensely to track width and therefore tyre grip. But I guess for all the gay boys out there that like the poofy little ones on the purple car, well, they aren't flairs boys. Sort of like having a bonnet scoop that isn't actually sitting over a hole in the bonnet. Just glued on for the wank factor. Sorry.
the car in the original post is a gtst.
CCW is making me a set of 18x11 "classics" so i can use 295-305mm tires with a +10 offset. ill probably still space them another 5-10mm so they fill the flares out. the center will be shotpeened graphite grey, lip polished, 4inch lip.
first of all, yea im looking for more width but im also concerned with rubber patch on the road as its a 600ish hp BC stroked RWD car. im just looking for all the traction i can get. sure it will look like a steamroller but it'll hook better than a 18x9 rim with a 255 tire and handle better too.
cosmetically, they look awesome to me, theyre going on with a gtr replica bumper, hasemi sideskirts and an abflug rear bumper/diffuser, FRP doors, hasemi canards. to each his own. i have had a picture in my head for 4 months while collecting this pile of parts and these were the last piece other than the spoiler. (voltex)
i was able to track them down in the UK, the abflug ones. they look a skoach differnet than the ones pictured but i found the ones i want.
function before form. its all going into the paint booth first week of january for a full fitting and respray, r33 gtr white with double the clear coat, jambs and all.
oh yes... you must post pics... or I will hunt you down;)
ill put something up when its finished cosmetically. those CCW custom wheels are only 2350USD by the way. about, or more, than one would pay for some pizza cutter width volks with offsets that soar like falcon. they are an american site that caters more to corvette owners (about the only american car that can use an 11-12in wheel) so not too many people know about them.
Edited by Travis Bickle
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
