Nice as the Nismo ones are, they aren't what I'd call flares, they're just body mouldings. I think the OP actually wants more track, which they'd be useless for.
Love the car in the original post, flares or not, silver BNR33 with white rims is an epic win.
Those flairs on the original post are just beautiful. Would add immensely to track width and therefore tyre grip. But I guess for all the gay boys out there that like the poofy little ones on the purple car, well, they aren't flairs boys. Sort of like having a bonnet scoop that isn't actually sitting over a hole in the bonnet. Just glued on for the wank factor. Sorry.
the car in the original post is a gtst.
CCW is making me a set of 18x11 "classics" so i can use 295-305mm tires with a +10 offset. ill probably still space them another 5-10mm so they fill the flares out. the center will be shotpeened graphite grey, lip polished, 4inch lip.
first of all, yea im looking for more width but im also concerned with rubber patch on the road as its a 600ish hp BC stroked RWD car. im just looking for all the traction i can get. sure it will look like a steamroller but it'll hook better than a 18x9 rim with a 255 tire and handle better too.
cosmetically, they look awesome to me, theyre going on with a gtr replica bumper, hasemi sideskirts and an abflug rear bumper/diffuser, FRP doors, hasemi canards. to each his own. i have had a picture in my head for 4 months while collecting this pile of parts and these were the last piece other than the spoiler. (voltex)
i was able to track them down in the UK, the abflug ones. they look a skoach differnet than the ones pictured but i found the ones i want.
function before form. its all going into the paint booth first week of january for a full fitting and respray, r33 gtr white with double the clear coat, jambs and all.
oh yes... you must post pics... or I will hunt you down;)
ill put something up when its finished cosmetically. those CCW custom wheels are only 2350USD by the way. about, or more, than one would pay for some pizza cutter width volks with offsets that soar like falcon. they are an american site that caters more to corvette owners (about the only american car that can use an 11-12in wheel) so not too many people know about them.
Edited by Travis Bickle
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
