As the title says,
I'm after a pair of those little factory fitment rear mud flaps that come out on the R32 GTS-T's. I would prefer black ones if available.
Send me a PM if you've got a pair.
Cheers :/
Scott.
https://www.sau.com.au/forums/topic/24589-rear-mud-flaps-r32-gts-t/
WHITE R32,
I don't have a pic of them but I know what they look like ;)
It's not really even fair to call them mud flaps considering they're so little. I'm guessing we're talking about the same ones.
They're quite small and mould to the rear gaurds bolting up with the two 10mm screws on the rear of the gaurd.
Do you have a pic of your ones ?
i dunno what they are worth mate... but i dont think they are really easy to come by cause i havent seen em on many cars....make me an offer keeping in mind they would cost bugger all to send cause they weigh nothing...
I'm not really sure what they're worth but I know if any of my mayes got a pair ( they import cars ) they'd cost me a case :D
If they're in very good condition I'll give ya $100 for the pair delivered. How's that ?
how about ill send em to u cod for $50 plus postage man... they are good no cracks etc but they need a clean up they have normal wear as u would expect from something that sits behind a wheel all day lol.... in general a 8-9 out of 10 .... if u agree and it all sounds good pm me ur full address and mobile number and ill send em off to u straight away....
WHITE 32,
Yes thanks, still after them. Just never got a message that you'd responded. Just tried to PM you but your mailbox is full.
Give me a call if you want and I'll give you the details.
Scott 0414-862-626
Thanks.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
