As the title says,
I'm after a pair of those little factory fitment rear mud flaps that come out on the R32 GTS-T's. I would prefer black ones if available.
Send me a PM if you've got a pair.
Cheers :/
Scott.
https://www.sau.com.au/forums/topic/24589-rear-mud-flaps-r32-gts-t/
WHITE R32,
I don't have a pic of them but I know what they look like ;)
It's not really even fair to call them mud flaps considering they're so little. I'm guessing we're talking about the same ones.
They're quite small and mould to the rear gaurds bolting up with the two 10mm screws on the rear of the gaurd.
Do you have a pic of your ones ?
i dunno what they are worth mate... but i dont think they are really easy to come by cause i havent seen em on many cars....make me an offer keeping in mind they would cost bugger all to send cause they weigh nothing...
I'm not really sure what they're worth but I know if any of my mayes got a pair ( they import cars ) they'd cost me a case :D
If they're in very good condition I'll give ya $100 for the pair delivered. How's that ?
how about ill send em to u cod for $50 plus postage man... they are good no cracks etc but they need a clean up they have normal wear as u would expect from something that sits behind a wheel all day lol.... in general a 8-9 out of 10 .... if u agree and it all sounds good pm me ur full address and mobile number and ill send em off to u straight away....
WHITE 32,
Yes thanks, still after them. Just never got a message that you'd responded. Just tried to PM you but your mailbox is full.
Give me a call if you want and I'll give you the details.
Scott 0414-862-626
Thanks.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
