Hey guys,
I'm getting my car ready for paint and removing all the necessary stuff, just a bit worried about damaging the trims trying to get them off. Anyone got any tips for me?
I've done a search(came up with a can opener :) ) and had a look through the workshop manual but it only gives a cross section of the trims. I'm assuming they just clip on but thought I should ask before getting heavy handed with it.
Trims to be removed:
Top trim of rear window
Top & side trim of front window
Door & quarter glass trim
Drip rail trim
Cheers Dan
Hey guys,
I've done a search(came up with a can opener :P ) and had a look through the workshop manual but it only gives a cross section of the trims. I'm assuming they just clip on but thought I should ask before getting heavy handed with it.
Drip rail trim
Cheers Dan
Harvo, it's not as daunting as you may think. I remember thinking the same thing prior to painting mine.
Front pillar strips that curve towards the sill just unclip with a little bit of force. Under that from memory you can undo screws to release the piece that hugs the windscreen.
Both front and rear top windsreen strips unclip, but be careful as the clips holding them can be rusted. These are screwed to the body.
The door trims along the top can only be got to once you've removed the door skins. You'll find about 4 small self tappers holding this strip. If your lucky they won't be rusted out like mine were.
The rear window trim is like the door trim, it has a series of self tappers that you can access once skin is removed.
As for sill, I left it on and masked it along with the trim that follows on from the rear window trim.
Hope this helps. just be patient with the strips that unclip, pry them gently as they can easily be bent out of shape.
Thanks mate,
Have all the trims off of the front and rear windows (only broke 1 clip) but when you say "door skins" do you mean the interior door cards/trims? when I hear door skin I think outer sheet metal of door. Either way I think I'll just mask them off.
Thanks for the fast reply,
Dan
Yea harvo, door cards if you like, those bits that require you to remoe the arm rest and window winders etc. It really is east to take them off and undo the self tappers and if your painting your doors it saves masking inside.
