I've had the Skyline for about 3 nearly 4 years now and own the bugger outright.... We are having to think of a more practical car :(and something in the Aust. market (lower cost of insurance). So what do you get for $25k after you've owned a Skyline? Yes I know it's true that most things pale into insignificance compared to one, but the change is inevitable.... Any suggestions?
  • Replies 61
my friend sold his s15 and he wanted something a bit cheaper and definitely more practical, he looked at the rexy wagon for a while. a tonne of bang and a lot of bootspace!
i'm cursed with never being satisfied.. next i want an M3, then an E55 and finally a 911t! then i will be able to sleep well at night hehe
Not sure about insurance... but an Audi A4 turbo, or maybe the V6 one. A little vague on the straight ahead but very nice cars.
Or an E36 325i, i would consider a Holden but too many aftermarket susp/engine parts which would mean it would cost me a fortune to modify as i wouldnt be able to help myself.
Audi RS4 - hands down the best station wagon ever made!
For those that don't know it's an 6 cylinder DOHC twin turbo intercooled monster (sound familiar?)
power wise it's 280kW@6100rpm and 440Nm@2500rpm
0-100 in 4.9.
not bad for a "family" car :)
edit: forgot it's 6speed manual and AWD :)
there's an RS6 which is basically the same, just not a station wagon.
how much are they?
From memory they were sold in limited numbers (like 15 or something in Oz) and were almost 200grand. Oh and noone has mentioned that Porsche actually built them, hence the Porsche logos on the brake calipers.
A nice Audi that may be worth a look if you have to have some GO, would be a '94 model S2 or S4. (2door/4door) They have 4wd, turbo 5 cylinder engines and the tuff Audi look. 4 years ago 40grand got you close, no idea of what they are worth now.
Based on the 100 quattro (later re-badged the A6), the S4 replaced that car's V6 with the venerable five-cylinder, iron-block engine. Equipped with a 20-valve alloy head, KKK K24 turbo, external wastegate and air/air intercooler, the 2.2 litre engine boasted immense low-down torque - no less than 350Nm was available at just 1950 rpm. And, if the driver was prepared to put his or her foot right down to the floor, an over-boost function kicked in, with intake pressure rocketing to 16 psi and torque rising still further to 380Nm at 2100 rpm. With 169kW available, the 1650kg leather-and-carbon-fibre trimmed cabin would then be propelled to 100 km/h in 6.8 seconds....and with a 6 speed manual.
But my preference is the S2.. but you may a well keep the Skyline
Woops, just had a look... i suppose i was dreaming that they had dropped into the 20s (Still around 40k if you can find one):)
Audi A4s fall into the price bracket though.
Speaking of Volvos, i just looked up the T5s, 5cyl turbo, manual (FWD???). Wagons start at 20k, sedans from around 22k on up
Eg .Volvo 1997 S70 T5 sedan, Turbo, in green with beige leather and suede, all electrics, alloy wheels, airbags, ABS brakes, 81808kms 26k
Am i going to be stoned to death for suggesting cars with a euro flavour... perhaps go with the Forrester, only i woudlnt be able to resist the temptation to modify them.
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
