while driving my 32 the other nite, the rear brakes started grippin up real hard. and was killin my speed hard.. piulled over then they were fully locked on.. went for drive 2day and they did the same but not as hard, didint realise til i pulled up and see smoke pourin off the brakes... :-( so i need help. wats causin this, and how do i fix it.. fronts work fine. cheers
https://www.sau.com.au/forums/topic/245971-rear-brake-problem/
If its one or two pads out of the four at the rear its probably just the pistons getting stuck in the calipers and holding the pad on the rotor. Get a rebuild kit from race brakes and pull them apart, clean them up and assemble with the new seals in the kit. Might as well do both calipers while you're at it. When i did mine i gently cleaned up any scoring on the pistons with 1200 grade wet and dry sandpaper.
