Alright guys, I've got a spare din space in my dash so i thought i may as well plonk some gauges in there for a quick reference to what the engine is doing.
So my question is; what is the three most important readings should I put gauges in for excluding boost?
https://www.sau.com.au/forums/topic/245978-engine-gauges/
I have electric oil pressure and boost gauge on my pillar and I have water temp reading from the ecu and another tacho on my indash screen via carpc/datascan (also has RPM and speed alerts).
Will be getting an oil temp gauge when I put an oil cooler on and will throw the gauge in the gaping hole where the drivers air vent used to be (previous owner had the mech. boost gauge there).
https://www.sau.com.au/forums/topic/245978-engine-gauges/#findComment-4279633
Oil Temp and Pressure and Water Temp as the one on the dash is basically useless, by the time it's reading above normal it well above 100 degrees.
Yup, noticed that too and that's why I take my readout from the ecu.. also I noticed the tacho in my dash is slightly out compared to the ecu :ermm:
https://www.sau.com.au/forums/topic/245978-engine-gauges/#findComment-4280084
bubba you've done exactly what I'm aiming to do in my car with the car pc. Are you running a power fc? I'm looking at running that into the car pc and a mate of mine is writing a graphics program to take the readings from the pfc tunning software and displaying it as a gauge. Damn... I thought it was an original idea to.
Back on topic though, since most of this build is trial and error I wanted to know which readings I should have separate gauges for as a back up (and it's a bit of a tribute to my 33). Anyway, I'm thinking Boost, oil psi & oil temp. Swapping out boost for water temp if I can find a good place to mount a boost gauge by itself. Does that sound right?
https://www.sau.com.au/forums/topic/245978-engine-gauges/#findComment-4280997
I'm running a remapped stock ecu, consult cable permanently plugged in and running Nissan Datascan for my readouts/logging. I also use RoadRunner as a media front end :)
If your mate is cluey he could make RoadRunner display stuff from Datascan.. *hinthint* :blink:
Edited by bubba
https://www.sau.com.au/forums/topic/245978-engine-gauges/#findComment-4281512
the regular AF ratio gauges that read off your stock sensor are rubbish. complete waste of time and tell you nothing.
the most important is oil pressure, oil temp and water temp. also important are fuel pressure and boost. then if you still need more look at EGT.
https://www.sau.com.au/forums/topic/245978-engine-gauges/#findComment-4281868
Big thanks all! :laugh:
I'm running a remapped stock ecu, consult cable permanently plugged in and running Nissan Datascan for my readouts/logging. I also use RoadRunner as a media front end :P
If your mate is cluey he could make RoadRunner display stuff from Datascan.. *hinthint* :D
Sounds like you've already got this sorted mate, I've got a brand spanker pfc so I'll probably stick with the original plan. What's roadrunner? And is datascan only for stock ecu's? Any pics of your setup mate?
Yeah I heard the same about a/f meters beer baron. Book in oil psi, oil temp and water temp!
Thanks again everyone.
https://www.sau.com.au/forums/topic/245978-engine-gauges/#findComment-4282867
Having good mechanical gauges is the way to go. Digital gauges run into dramas more often then mechanical.
+1 for Beer Baron's answer.
Oil Temp (after cooling), Oil Pressure, Water Temp, Fuel Pressure
If this car gets thrashed or raced on a regular basis and makes or will be making descent power eg. 300rwkws+ then another Oil Temp before cooling, assuming wetsump system here probably in the pan somewhere would be ideal or inline between pump and cooler. (Good for keeping an eye on bearings)
If you get digital gauges and tap into the computers sensor wires...if that sensor plays up or fails(which they do when they are XX years old), your gauge will only see the same readings or lack of....having a second independent sensor will stop that from happening. Gauges and sensors seperate to OEM is ideal.
Edited by r33_racer
https://www.sau.com.au/forums/topic/245978-engine-gauges/#findComment-4282921
I'm definatly aiming for digital gauges this time around, after pumping the sump into the cabin of a previous car via a deteriorated gauge hose, I'd rather risk electrical failure. I'm also definatly using seperate sensors to the factory ones. They wouldn't be a very good backup system if they are running off the same pickups they're supposed to be backing up lol.
https://www.sau.com.au/forums/topic/245978-engine-gauges/#findComment-4285298
  • 5 months later...
sorry to dig up an old thread, but im finally wanting to install my oil temp gauge. its been sitting in the car for quite some time, however has never worked. i dont run an aftermarket oil cooler in my setup so was thinking of welding the fitting into the sump.
where do most people normally have this gauge feed coming from?
cheers
https://www.sau.com.au/forums/topic/245978-engine-gauges/#findComment-4612695
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
