I have a Autech 260RS and when coasting up to a corner there is a knocking coming from the front LH side, it matches the road speed, stops when u brake and stops once u accrelerate again. happens when the wheels are straight aswell? Has only started doing it last day or two.
Im thinking it may be a CV joint?
I have had the 4wd light on for about a week now, havnt been able to see whats wrong with it been to busy, im pretty sure its got a guts full of air as the line has been off and havnt bled it yet.
any idea's?
cheer's
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
