does anyone have anything reasonable to offer me for my gtr it needs to go NO SWAPS need all the moneyi can get at moment cheers im currently in the process of finding out exactly what kind of garrett turbo's are fitted and also the cams and cam gears should no soon keep u posted but i seriously gotta get rid of her soon cheers!
Just wait man. I am trying to sell one too but there isnt a whole lot of money moving around at the moment. Dont go to low. IT IS WORTH THE MONEY. Good luck man.
  • Replies 56
hey mate tell me about it !! i no its worth the cash but i gotta get rid of it soon otherwise i will loose the venue i booked for wedding cause i wont be able to pay!! and that means a very angry missus HAHAHA :blink: so it gotta go asap !!!!
Good luck with the sale of yours mate hope your luck is better than mine!
Have you had the engine compression tested?
What year model is it?
What suspension (coilovers adjustable or just lowered springs?)
Does it have an aftermarket clutch?
Any oil leaks?
thanks
h
Hey mate no i havnt had it compression tested
it is a 1993
heavy duty clutch
def no oil leaks that was one of the biggest things i looked at when i purchased it!!!
Also just to ad it has had all the belts changed including timing belt just before i bought the vehicle around nearly a year ago so nice and fresh
Just found out the turbo's i have are apparently garrett gt3070's if that makes sense i'm not sure im not mechanicaly minded i'm finding out if they are decent or not cause i don't no!!!! but the guy i spoke to told me they where fairly decent!
Engine bay shots will be up saturday!!!
Which Saturday :D
Well I am not sure if the info you have is accurate, because depending on the trim etc, those turbos are rated at between 350 and 500 HP EACH!
hey sorry guys this saturday coming! i couldn get done this sat got called into work and was too late to do when i got home.
As for turbo's it's what i was told they were but cheers for the info i will try look into it further , are there any numbers i should look for on the turbo's that would tell me exactly what they are? i might just try pull everything off and have a better look , but as most of you guys will no they are a pr@*k to get too!!
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
