Just a little curious over this one..
Lots of people seem to be selling their skylines at the moment (including me :) ). After a bit of a lull, there are a stack of skylines that seem to be going up forsale at the moment. In VIC, there is about 10 skylines i could probably name that have been put up for sale recently or been sold. Why exactly?
1. People cashing in while they can still get good money for modified cars with the new RAWS system?
2. Some of the younger guys are realising how much it actually costs to keep a skyline on the road after owning one for 6-12 months?
3. People need money for other things such as houses, etc.
4. Insurance costs are going up too much and cops getting to heavy on imports?
5. People want more rice, cheaper TCO and things rather than pure power these days.
I guess mine is a bit of a mix between 1 and 3.. what about everybody else?
https://www.sau.com.au/forums/topic/24601-why-the-sales/
well, my hubby lost his licence for a year so we decided to sell his GTR - no point keeping it sitting in the garage for a year. I've been driving it but it uses so much fuel! It's just a waste sitting there depreciating in the garage. He'll most likely get another one later when he gets his licence back next year
https://www.sau.com.au/forums/topic/24601-why-the-sales/#findComment-524287
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
