Just turned on my 360 and had to d/l an update that took 30 mins....i know my net is a bit slow...installed it and it totally changed the entire dashboard.
I dont like it much. Microsoft should have just left it the way it was.
What does everyone else think of the new dashboard design??
https://www.sau.com.au/forums/topic/246024-new-xbox-360-dashboard/
Looks like a mix between PSN and the Wii :P
I was thinking the same thing lol
Just seemed like an unnecessary download to me....i just wanna get on and play games not spend ages installing updates all the time
yeah it's very Wii ish but you'll get use to it
the only options I like is that you can turn off the consle by just pressing the guide button (instead of holding the guide button down) and able to install games onto the HDD.. yes you still need the disc in the drive but it uses it to verifiy the game and then it will run all on the HDD
I've tested with Midnight Club: LA and GTA IV (two games very notrious for pop-ups and the disc now keeping up with gameplay) - load times improved by about 4 seconds for both and has very minimal pop-up
Not too good if you have 20GB HDD but i've got a 120GB HDD and you can fit about 10-15 games on the HDD and still space for profile and saves.
another good reason why psn rules,
been downloading games from day dotand u don't need the disc... haha
and u can throw in any 2.5inch hdd in her, i just put in a 250gb hd, not that im gonna use it all.
but playstation FTW!!!!!!
dont get a ps3 then.. fuuuuck that thing shits me, every time I turn it on i have to update some thing, and it's so f**king slow as well
Now all you need is a good game to play on it lol
maybe its a good thing i have never bothered to connect my ps3 to the net then :worship:
but then again i never play it either....seems to lack good games.
Are you talking about games downloaded from PSN?? I'm talking about latest titles such as mirror's edge etc. I belive that PS3 will install some files so it acts as a pre-cache for games
Don't get me wrong I would love to get a PS3 for the pure fact or blu-ray games and FREE online play...unlike the X360 where you need xbox live gold account to play (too bad for me that my console is banned...but who cares)
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
