About a year or two back along the Tuggeranong Parkway i used to see a Landcruiser or something similar towing a trailer, and that was an undercover car. Had seen it on two seperate occassions pulling someone over. I think they are getting a lot more sneaky with what they are using because it's pretty easy to spot the undercover commodores and falcons.
As for the cops flashing their lights to avoid traffic lights etc, i've seen that myself. I'm assuming they have the power to do that if it is for a legitimate reason. Still, give anyone power and there will be the few who abuse it.
a mate of a mate has red and blue lights behind mesh in his front bar...very bright and i reckon if he was driving behind me n flicked em on i would pull over.
which he said is what people do...good for a laugh i guess...but im presuming their are others like it.
you can get in major major trouble if you got busted doing that...
  • 1 month later...
indeed mate. i saw it like 3x in x-mas day. black glossy ute with Led & sirens pulled over a stock 180sx near moosehead.
just beware of this fancy ute with lousy muffler trying to "bait" u.
To add to the undercovers vehicle stock there is often a current mitsubishi silver sedan cruising the Tuggers xpress way from Kambah lights to the city and back.
Is it just undercover cops with nothing better to do than go on speed patrol?
All the serious crims have been arrested!
Im sure there is a silver VE SS ute too. there was a cop car and the VE parked behind the other with only two cops one leaning on the back of the cop car and the other leaning against the front of the VE chatting. have seen that landcruiser. and there was a dark blue landrover when i was working at rolfe a few years back.
Yeah I thought that car looked a bit too suss.
with my car currently off the road getting a 25 conversion we took my mates 300kw sleeper VLT to canberra. sitting at a set of light on northbourne a grey VE omega pulled up, man and woman inside dressed in casual gear. tryin to get me to race them. had a quick look at the dash and saw the velcro pad in the center.. bit too suss for me so i just took off slow.
Then saw the same car, now with some light on the dash pulling over a couple of blinged up, 22inch wearing snot boxes!! I bet a few ppl got in the crap from not being carefull enough!
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
