From the power fc FAQ, this circuit diagram is the closest I have come to an answer
to my query:
http://paulr33.skylinesaustralia.com/docs/...eccs-wiring.jpg
So I understand that IGN on powers up the pfc ecu (or the stock ecu) and, START
makes the ECU light up the ECCS relay and the Coil relay: the ECCS relay
powers up the CAS sensor and the AFM (engine sensors) and the coil relay lights
up the coils.
ECU senses cam position etc etc & fires & car starts.
What I don't understand is what happens to trigger the power-fc to save state
and the sequence during shutdown..
I've seen several posts about in other forums particularly where either
the ECCS relay is broken or the wiring loom is wrong or the engine has been
swapped (wiring loom wrong) and the save problem is in the power-fc faq.
So.. ignition goes off and .. what? the ECU, still powering itself through ECCS,
writes all the changes to non-volatile memory, then does _it_ turn off the ECCS
relay itself by pulling pin 16 to ground? (which withdraws power to the engine
sensors and other pins on the ECU)? is the ECCS relay just a regular relay like
any other or is it more complicated inside?
If it works as I describe does simply supplying non switched 12v to pin 49/59/109
with an inline fuse, does that allow the power-fc to save its state (although since
this would leave power to the ecu always, perhaps it be a drag on the battery).
The reason for all this is I have a car alarm that is so knitted into the wiring that
it is able to pull ALL power from the ecu connector on ignition off.. I'm faced with
a choice - pull the dash and pull out the entire alarm, or solve the immediate
problem to get power-fc to save state..
https://www.sau.com.au/forums/topic/246090-power-fc-how-it-saves-its-state/
The pfc needs 1sec more 12V at pin49,59 when you cut the voltage at pin 45 (so when you cut ignition).
12V Ign at Pin 45
12V Permanent at pin 58
Pin 16 to the relay and suply the relay with battery voltage with a new wire from the battery with a fuse so you will be sure thaw this voltage you will not cut from alarm.
so with the ecu unplugged you should be able to see 12v on ecu harness pin
16 and 58.. and if you ground 16 (which turns on the ECCS relay, listen for a click),
you should then see 12v on 49,59 and 109 as well ?
Is that a good test?
Oh you will melt something or you melted!!!
Pin 45 12V Ign
Pin 58 12V Permanent
When your ignition is on (red lamps at dash), so when the ecu have 12V at pin 45.... the ecu gives a ground at PIN16!!!
This ground opens the ecu relay!! So the ecu relay sends 12V to the 49,59!
If you gave or if you will give 12V at pin16 you will melt this pin and you will not anymore ground exit. (if you did it, I will tell you what solution I found)!
Ecu relay..
1 and 3 needs one ground (ground from pin 16) and one 12V permanent.
3 and 5 at 3 12V permanent and at 5 a wire that goes at pin49,59.
To understand which pin is the 3,5,1,2 see under the relay... it has some small numbers near each pin. The scheme at the face of the relay (that writes NISSAN) isn't with the right way printed.
Just read what I said you to connect at the relay and look at the metal pins to find some very small letters nears the pins and you will see the numbers.
Pin 45 12V Ign
Ecu relay..
thanks, no I didn't do anything! just hypothetical.
the only time I almost melted something was undoing the battery live terminal
with a spanner and despite being careful in the limited space it touched a bit of chassis
and the zaaap the spanner got warm instantly, luckily I yanked it before it stuck!
ok..
without an ecu connected, just looking at the connector, I was trying to imagine a way to test if the loom
is operating properly with key on, then key turning off. Just test with multi-meter .. I think from your explanation
I can see what is necessary..
with ecu connected it is hard to know what each pin (each wire) has ..
Edited by r34nur
You should be able to shove a probe in the end of each ECU pin (from behind, you can still access the other end of the pin) and earth the other probe of the multimeter to check for 12v across each pin as you turn on, or turn off the car, and ensure everything is operating as expected.
(edit: what he just said ;))
  • 7 months later...
  • 2 years later...
I know this is an old thread but can you actually hear this slight delay (on shutdown) in the ECCS relay enegizing - can someone confirm this on an R33 rb25det? I.e. so you should hear the engine shut down when you turn the key - then about a 1 sec pause before you hear the relay kick in?
Is the ECU programmed to delay 1second before triggering that relay, is that how it works?
Why does the stock computer require that delay? is it for writing fault codes? As I understand the PFC requires it for tune writing.
Thanks
Yeah you should be able to hear the relay click off after a short delay.
I'm not 100% sure on the stock ECU, but it may just be to save Crank position and general state of the car when it turns off to help with startup
But I dont know for sure, havent had a stock ECU for a while now
thanks for that.
Back up on some of the other threads it talks of a permanent 12v to pin 58.
My r33 has 12v to that when ign is on but as soon as you switch the ign off this voltage drops but fairly slowly. Drops to 4v then drops about .1v every few seconds. Maybe the alarm is connected in with this 12v feed?
I would think this is the reason my ecu shuts down earlier as it would need the constant 12v to allow the eccs to shutdown the computer.
Thinking of running a permanent 12v line from maybe the clock over to the ecu so that pin 58 does in fact have a constant 12v. Unless there would be a closer constant 12v feed than to the clock.
I don't want to wreck the harness though. Would I be best tracing pin 58 wire back slightly and splice this wire I run in at that point?
Does the above make sense to anyone. It is strange my pin 58 doesn't keep 12v ..
  • 3 years later...
  On 24/11/2008 at 1:41 AM, paulr33 said:
once confirmed, please advise
will add to PFC FAQ
This is a very old tread but we have the solution for years and fixed many PFC's with that issue.
If anyone has got that sort of problem please contact us on http://fc-hako.com/pfc/contact/
Will be fixed and tested in one day. If the issue is with engine harness we will advice you how
to test it before shipping the PFC to us.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
