G'day From A Yank Transfer
bambam1
 Share
Thought I would post up and say G'Day to everyone.
I have been in Melbourne for a month now and just getting settled into my new flat downtown. Man this weather is really unpredictable. Looks like I will be here through June, but wish it was longer as I was thinking of looking at importing my GT-R from the US. Have seen a couple of R33 and a 34 driving around town and makes me miss my new baby.
I have one of the early R35's on the East Coast of the US. (I am also a member of NAGTROC, myGTR.com, Lotustalk and my350Z.com) It's Gunmetal with the Cobb Access Port: Stage 1 tune. Already put 8,500 miles on it in the first 2 months for a cross country Rally (pavement only, not dirt Rally stages). The AP has given a great boost to the midrange power level and while I have not dyno'd it, I have had exchanged rides with some other new GT-R owners and everyone agrees it feels much faster and responsive in the lower gears.
Cheers mates, and I hope to run into some folks around the Melbourne area when the weather gets better (if it ever stays warm for more then 1/2 a day that is).
--B
Edited by bambam1
Thanks for the note.
I know the newbie threads tend to be ignored, so no problems there.
Australia appears to be a pretty cool place, but I have to say this weather in Melbourne is just plain strange. The temp differences take some getting used to.
Hopefully I will get a hire car and do some sightseeing around the Melbourne beaches and coastline one of these weekends. Won't be my GT-R, but will make the best of whatever car I can get ;-)
 Share
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
