If I install an RB25DE with carbs in an early Skyline with an upgraded ignition system can I completley eliminate the ECU and wiring harness? Because it seems like the only things the ECU really needs to control is timing (which will now be handled by the ignition system) and air/fuel ratio (now controlled by the carbs).
Thanks! :ermm:
https://www.sau.com.au/forums/topic/246188-rb25de-with-carbs/
yes its a possibility
here in australia there was an early model Nissan Patrol ('88-90 i think) that came out with the RB30 but in carby form
if you could get hold of an intake manifold it could be possible to install a big holley 350 double pumper or something on it
thats crazy, interesting to hear what that would sound like..
... shit...
lol
feed it triple trumpeted webbers or even SU's and it would be allright though
Wouldnt be hard to custom make a manifold, would be better to start fresh, and make a short runner manifold feeding diectly to carbies instead of modifying the dirty 30 manifold to suit a 25
Edited by SKiT_R31
The question would be, WHY?
Even if transplanting, the engine is still from a "new" vehicle, and hence, when being engineered, needs to meet the Emmision levels of the engine.
Hence, going Carby, you will not meet these emissions, so I'd really have to ask WHY you want to do it?
If you get a whole loom, plus ECU, it really is only around 5 or so wires you need to modify to make it all fit. Much easier the customising manifolds.
Completely remove ECU and wiring harness...
but replace with custom inlet manifold and multiple carbies, you'd also need to use a different fuel pump as the EFI pump will have too much pressure for the carbies?
Potentially, yes it could be done, but question remains why you'd want to when you could get better tunability, resulting in more power and probably less fuel consumption, not to mention safe guards of things like knock sensors.
If you want induction noise, throttle response and better breathe-ability, you could make a custom inlet with individual throttles but still retain fuel injection.
induction noise, throttle response and better breathe-ability having 6 throttle bodies and no plenum if you were to use 3 side draught webbers, dellotos or so on.
Make a custom throttle with ITB, with individual air filters.
Same throttle response, same induction noise, no plenum, better tuneability, more reliable and consistent through varying weather patterns.
I still need to ask why you want to remove the ECU, considering, placing it in any car in NSW would make it illegal with ECU etc removed.
last time i checked, running an aftermarket ecu was also illegal.....
I would much prefer ITB's + MAP, but i can see why you would want carbies... and the induction/exhaust noise would be different, and you cant say for sure that you would get more power out of EFI, maybe economy and drivability and flexibility (weather, atmosphere etc) but it can be cheaper and a whole lot easier with carbies. Esp if you were to have some rediculous cam setup, aswell as other modifications, where you would need a damn good tuner to get good power (and lets face it, its hard to get a tuner so passionate to sqeeze every last kw out of a car by spending hours dicking with injector timing etc.)
Edited by SKiT_R31
It says he's from Japan so our laws won't mean anything to him LOL
Edited by MintR33
when i run modifird production in speedway the rules said we had to use a 350 holley altho it could be converted to run methanol.
a few of the guys running vl's at the time used the nissan patrol manifold with a methanol holley and made good power out of them .
problem was finding the manifolds it was a problem back then and prob even worse now
cheers mid life crisis
Thanks! :D
What's going to tell the "modified ignition system" to fire the spark?
The ECU does more than simply "control ignition timing".
If you are after the carby induction sound, you can run injectors in a weber-style manifold fitted with trumpets (have a look on www.efihardware.com). That way, you get the fuel efficiency of EFI with the induction "roar" of Webers.
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
