Hey,
I want to install my gtr injectors and z32 afm into my r32, but having a standard ecu the car wont be able to start..
I was wondering if anyone could make me a eprom chip with the injector and afm values changed, just so the car is drivable.
I have installed the socket into the ecu, so all i need to do is swap the stock chip with the programmed one ;)
Thanks
Patrick
https://www.sau.com.au/forums/topic/246234-after-a-ecu-chip-for-r32/
dr drift would have something to suite but you would then need to put it on the dyno for fine tuning
yeah i only want a temp solution just to drive it to a workshop. Else i'd need to pay to have the injectors+afm installed once the car is at the tuners
well if the workshop who is tuning it can't or don't provide a remap then just put it on a tow truck
towtruck sounds expensive and a hassle.
Ceffie has kindly pm'd me with a cheap offer for a chip to suit my temporary needs.
Thanks all
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
