Cheers Andrew..Yeah mate its bloody good to finally see it all together, its about 3 weeks shy of 1 year since I dropped the N1 block off and the whole build began but one can really see the light at the end of the tunnel. Just got a few more things to bolt on, injectors,fuel rail, the 2 month wait hose and few little odds and ends and all done.
The plenumn needs a few mods to get it all to fit flus some pipe fabrication for intake from intercooler. Got to than Paul Dirt Garage for his input and pics as well as Ross (Giant) , thanks fellas !
I'll try get some better close up pics of the plenumn mods on the weekend but you can see the fitting we welded in for air sensor.
Clutch was normal Super Coppermix Twin plate rated at 570ps/493kw but has been fitted with Super Coppermix Twin Competition Model clutch cover and modified and now rated to 780ps/574kw so should ample to handle power output. Be interesting to see if there is ant difference in pedal feel.
Also picked up a bit of a suprise a month or so back. Brand spanking new, in the box GT500 Engine block which I'll be bringing back to oz next year!! I'll put up some pics of that puppy soon.
  • Replies 286
Marko..
Originally we were going for an easy 600ps around 440kw by my calculator(http://www.locost7.info/converter.php) but guys reckon we should get closer to 650ps (470 odd kw) but whatever it should be plenty.
Richard
Thanks mate. Yeah I cant wait to hear it fire up, should be soon..
Heres a few more pics..
More head shots during port and polish
Sunline Racing Carbon Cooling panel
Friend of mine makes these Carbon Grills for GTR33's
More pics to come later .......
head looks good. same as mine basically. removed squish pads on one side. gives a compromise between response (you loose a little) but you can run more timing/boost with less detonation without them. looks very nicely done. :(
head looks good. same as mine basically. removed squish pads on one side. gives a compromise between response (you loose a little) but you can run more timing/boost with less detonation without them. looks very nicely done. :O
Those pics were before polishing was even finished.
HKS do a build photo documentery for customers and will get CD of pics when all finished. I was away when head was finally done so will post up finished polish pics later.
Thanks for moving the post :)
filf!
cheers :)
GT500 block...Hmm.... I am so jealous!
Yeah that was a find and a half !!
Head work looks great.
I sent the HKS guys your build V-Cam build Matt to have a squizz at, be interesting to see what they think, reckon they will be impressed !!
Throttle Body Port & Polish
Using Standard manifolds but they were given the port/polish treatment as well. Ay time of pics not quite finished!!
Proposed new position for intake pipe to plenumn
ENGINE AND GEARBOX IN......Hoobloodyray!
Cam cover is just dummy cover to prent knocks and scratches etc
Good clearance with Hi Octane sump
Well off to Nismo Festival and Nagoya for a week of debauchery !!
Everything with the engine should be finished by the time I get back and time to fire it up !! Cant wait!1
Only thing we are waiting on is some silicon hoses from Samco.
Well as per usual while I was away at Nismo festival there were a few hiccups with a delay on hoses and couple of gremlins and the fact that 4 customers decided they wanted engine rebuilds done by xmas that has seen the car not completed yet but should be fired up Tues or Wed this week fingers crossed.
Heres some pics on work to date !!
The end is near!!
New 90mm Inlet Pipe to Plenumn and new hole position
New BOV
Hopefully in the coming week I can throw up some completed pics.
Out of interest would like to hear peoples opinion on running the HKS BOV.
The HKS guys reckon the standard GTR's leak slightly and they want to run to Atmo but going to run plumbed in so hopefully dont get defected back in oz and could not stand hearing a loud pssshhht all bloody day long.
Opinions on aftermarket Bov, + or - welcomed
im not sure about hks bov's but i do know that factory gtr bov's are well and up for the task on big hp setups
where is dirtgarage (aka gtr wikipedia) when u need him?
Yeah I wanted to stick with the standard but they swear they leak and over here everyone seems to run aftermarketand to atmo.
I wouldn't worry about it too much. it's easy to change. rather than p1ss them off by telling them everyone in aus reckons run standard plumb backs just run whatever they recommend. if you hate it or have problems down the line it's not a big deal to change back to a standard type set-up or just buy a trust type R which work great either plumb back or vented to atmosphere. I have run both ways and never had a problem with either. my last GTR making around 330rwkw ran standard and the current one runs twin blitz ones vented to atmosphere and both set-ups work fine.
Thanks Richard..
Can you or anyone clear something up for me.. is running the Bov to atmo illegal in OZ ???
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
