I imported this car as a stock late model R32gtst and built it up as though i was going to keep it forever. But things change and regretably ive got to let it go.
The car is a late 1993 model R32 gtst M Spec with 99000 genuine kms. I have recently finnished a full rebuild (car was off the road for about 3 years) which included forged 1997 R33 RB26 engine, single gt35r turbo, R33 gtst gearbox, Autronic SM4 engine management, full fuel system, brand new mechanical diff, etc, etc. The car has recently made 350rwkw and 573Nm at 18psi and was tuned by Dave at Silverwater Automotive in Sydney. I have spent over $60 000 on this car and have all receipts. I admit that i am anal retentive and obsessive compulsive, so be assured that nothing other than top notch gear has been used and absolute care has been taken with the car. The car has not been used in motorsports events of any kind.
I apoligise for the long post and large images, but i want any prospective buyer to share my enthusiasm for the car and the amount of work that has gone into it. Im not going to sell it to just anybody, so no tyre kickers. Interstate buyers are more than welcome.
Further details:
ENGINE:
1997 R33 RB26
86.5mm CP Pistons
Prepped rods
ARP studs and bolts used throughout
9.5:1 compression
Brand new ATI harmonic balancer
N1 oil and water pumps
Tomei head gasket and oil restrictor
Tomei sump baffle
50mm Alloy radiator
Twin Ford Falcon EF thermo fans modified and placed in front of the radiator. These are extremely efficient
100mm intercooler with polished stainless piping.
19 row Earls oil cooler with remote filter
Custom baffled oil catch can with remote oil filter mount.
Garrett GT35r highmount turbo with 1.06ar turbine housing
K&N pod in the guard with 4 inch inlet to turbo
Thick walled stainless manifold that has been modified with extensive supporting to prevent sagging
Tial 45mm wastegate
Tial 50mm BOV
All hot bits have been ceramic coated and exhaust wrapped
Brand new 3.5 inch stainless exhaust with custom mufflers and stainless hangers. A 4 inch metal cat is also used, but i also have a seperate front pipe with dummy cat and provision for venting the screemer to atmosphere.
Autronic SM4 ECU
Comprehensive stainless steel heat shielding around ABS, above manifold and around power steering pump
Everything in the engine bay has been highly polished (not chromed) including the engine covers, plenum, all stainless heat shields. Even all fasteners have been replaced with stainless items and polished.
All hoses have been replaced either with silicon or genuine Nissan items. Earls braided hoses and fittings are utilised extensively, and Earls Flame Guard has been used to protect hoses in hot areas.
I really wanted to make the engine thermally efficient and, with the heat shielding, heat wrap, ceramic coating, Flame Guard, vented bonnet, larger radiator, oil cooler, and massive OEM thermo fans, you dont burn your face off when you open the bonnet.
FUEL:
Walbro in tank lift pump
2 litre surge tank with baffles
Bosch 044 fuel pump
Magnaflow fuel filter
Edelbrock fuel regulator with fuel pressure gauge
modified gtr fuel rail with 2 x fuel pressure gauges
Sard 700cc injectors
All fuel lines are super expensive teflon lined braided hose (no fuel smell) with earls fittings and weld ons. Hicas lines were utilised as fuel lines under the car.
DRIVELINE, BRAKES AND SUSPENSION:
R33 gtst gearbox with Redline lightweight shockproof oil
Jim Berry modified Nismo single plate clutch
Freshly reconditioned master cylinder with stainless sleeve
Nismo slave cylinder
Braided clutch line directly from master cylinder to slave cylinder
Custom 1000Hp tailshaft
Brand new Kaaz 1.5 way mechanical diff (done less than 500kms) with R33 4.3:1 crown wheel and pinion
Standard Mspec calipers with ABS as standard
DBA grooved and cross drilled rotors all round
New braided brake lines
HICAS removed (including all lines from engine bay) and replaced with lock bar. Power steering pump modification done.
Brand new suspension from Sydney kid group buy. This includes Whiteline springs and sway bars, Bilstein circlip adjustable shocks, new notathane bushes everywhere, pineapples set for max traction, adjustable front and rear camber kits.
INTERIOR:
Trust/Greddy boost, oil pressure, oil temp and water temp electronic peak/hold/warning gauges.
Digital intercooler inlet and outlet air temperature gauges
Greddy turbo timer
Pivot progressive shift lamps
Isotta leather steering wheel
Sparco foot pedals
Momo gear knob
New leather gear boot and handbrake boot
Autronic boost control with on/off (spring pressure only for low boost) and medium/high boost pressure settings
Custom aluminium chequered plate floor mats powder coated black
Top of the range Poineer head unit
Competition Pioneer kevlar 6 inch splits in the doors
6 inch Pioneer speakers in the parcel tray
12 inch Pioneer sub in custom sealed box in boot
4 channel Pioneer amp running sub and splits
Custom aluminium battery box in boot housing a dry cell battery
Standard sunroof
Mongoose alarm with remote entry and led lights in the doors
The interior is in mint condition with no rips, tears or marks anywhere. The carpet is in brand new condition.
EXTERIOR:
Enkei Tarmac Evo 17x8 inch wheels with no gutter rash
Brand new Federal RSR DOT approved semi slick tyres; 235 front and 255 rear
Rolled rear guards
East Bear FRP vented bonnet
East bear mirrors
GTR front bar
GTR grille
GTR bonnet latch
Debadged boot lid with holes soldered
Tinted windows
Comprehensively rustproofed everywhere including inside doors, engine bay, boot etc.
The original paint is immaculate and is kept detailed using Meguairs products and is garaged and covered with an indoor car cover.
So i think thats it. The photos dont really do the car justice, but im sure you get the idea. Im in no hurry to sell the car so if it takes a while i dont mind. Im looking for the right buyer, so for interested enthusiasts, dont hesitate to contact me for any queries.
Im starting at $27000 negotiable. I dont care if other 32 GTR's are 20 grand; theyre not this car and i dont want to hear it. Dont forget that this car has done about 5000kms since a complete rebuild and re registration. I have carried out all the installation and fabrication work, but the engine building was left to the experts. Due to the higher than normal compression, the car is great to drive off boost and is acceptable for everyday duties. I really wanted to build an all round car, and i think ive acheived that.
All modifications have been engineered, and all receipts and import documentation are available for inspection. A comprehensive photo diary of every modification is also available for perusal. I also have all the air conditioning equipment that was removed and many other spares if the buyer wants them.
I can be contacted on 0414972596 anytime. The car is located on the Central Coast, NSW, about an hour north of Sydney.
Thanks for reading,
Shaun.
Edited by Shaun
  • Replies 44
Thanks guys. Alot of work went into it. Theres about 400 hours of poloshing in the engine bay! i hope someone gets as much enjoyment out of it as i have!
I actually had no idea how much to put on it, as R32's like this rarely come up, but as always the price is negotiable.
Edited by Shaun
Good luck mate I've watched the built for the last 12 months atleast and I too am doing what you have done and that price seems fair, some people don't understand how much time and money go into projects like this, again good luck.
Very nice car mate
The air conditioning - Interested to konw what it would take to get that working again. Will the condensor still fit in or do the thermo fans now occupy that space?
Very nice car mate
The thermos do occupy that space, however, ive got the standard clutch fan that can be bolted to the water pump pulley as normal. Alternatively, conventional thermo fans could be placed behind the radiator, and the condensor could be replaced in the standard position. I just liked the gap between the engine and radiator. Its just a matter of bolting all the A/C stuff back on. Ive got it all.
No part of the body has been cut for any modification done, so the buyer can easily customise the car to suit his purpose fairly easily.
Oh, ive also got the standard bonnet and latch.
Paul, thanks for your comments mate; ill still call you up :)
Move over Suddam Hussain! We just found where you were hiding the WMD's.
Nice car mate! This this is a fine example of the power cars have over men and their wallets. Tell me if you had a girlfriend before you started this project is she still with you know.
Such a nice ride!
Such a nice ride!
She's stuck by me the whole way and loves the car as much as i do! It certainly is a snow ball effect with money and mods, but someone is going to capitalise on my loss and get themselves an awesome car for a great price.
Cheers.
Had some time to kill today and put my R32 gtr wheels on the car. I reckon they look great. Ive had these wheels for about 2 years and have never put them on the car. Theyre in such perfect condition, that i put them in garbage bags and stored them away.
PS They dont come with the car ;)
Rochford you are so anal...that shed is disgustingly clean!
Hahaha, its true, i admit it! I cop sh1t over that all the time :P
I couldnt get onto that link because im at work, but sorry mate, not interested in swaps.
Shaun.
Check out the link at home or something. Ive got a heavily modified s15
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
