I was recently given a offer i cant refuse, as i was helping my parents clean out the garage the other day i found that i have a whole heap of stuff i need to get rid of etc, so here is my first item for sale
Item: Set of original series 2 stagea rims (4), 16" x 7" wide with 205/55 tyres, Standard skyline PCD (5 x 114.3)
Condition: Rims are pretty good; need a clean couple of scratches on a few. With a clean and a polish these are less noticeable. tyres to me look like they will pass rego
Price: $300
Not asking for much here,just need to get them out of the garage...
Contact me on my mobile on 0410491185
or pm/post in here
i am located in Campbelltown but work in bankstown so whatever works best for people.
cheers
Jason
https://www.sau.com.au/forums/topic/246266-fs-stagea-wheels-and-tyres/
Ah bugger!!! I had 2 wheels crack on my car and I needed a new set of wheels... I forgot about this thread and just bought another set from a japanese wrecker... Bugger!! I paid $320 for the other set without tyres too!!
If you have these after christmas I'll send you a PM... Or send me a PM.. I'm still going to be after a set of 16" rims to put snow tyres on.. But not with my budget before xmas..
Spewing that I forgot about these!!!
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
