Hit a gutter last week, took the car to a tire place to get an alignment coz it was badly out. Guys told me I had damaged the "knuckle". Damage is on the right hand side, car is a 32 GTR.
Can I get a knuckle from the left side or does it have to be from the right?
How hard is it to remove/replace a knuckle?
Is it safe to drive the car around on short trips?
Just looking for some basic info
TIA
-Michael-
https://www.sau.com.au/forums/topic/246267-damaged-suspension/
1. no
2. some effort but very diy-able as wit most things
need 2 remove 36 size hub bolt then remove handbrake springs at the hub,den bench vise the hub and undo the 5-6 bolts
3. depends how bad the damage is, i guess you can limp a 2 b to get parts but no high speeds/fwys/hwys, best not 2 drive it if its that bad
guessing these are the rear knuckles, as theres sum1 on ns.com is selling a pair
1. no
(assuming we're talking rears here)
I broke a couple of quality 1/2 in drive breaker bars trying to get that 36mm nut off. Workshop with 3/4 drive rattle gun was required... so not completely DIYish for me. I have two second hand knuckles now, but i might need both. PM if you get stuck, maybe i wont need the second. DECIM8 bought a new one from Nissan (needed to come from Japan). PM him if u want a new one.
Here's my thread clicky
Thanks Guys,
Not too good with the DIY stuff, so might leave it to a mech.
Its the front right hand side one, rears are ok as far as I know.
Can I used one from the rear for the front?
-Michael-
Bad luck on the damage, I was hoping that you only put out your alignment :(
You probably can limp it around safely for a little while, but it is going to be wearing your tyres out because it is out of alignment so it will definitely be better getting it fixed sooner rather than later.
When I hit a gutter in my car I bent some parts, not too sure if a "knuckle" was one of them. The only thing I can think of is you might have bent the tie rod end (like I did) or possibly the inner tie rod. These are the only things I know of that could be described as "knuckles." Look how far my 4 years of being an electrical apprentice got me towards becoming a mechanic :D
This is what I'm talking about.
The knuckle I imagine are the parts at the bottom of my photo. If this is the case what I did is bought a brand newy from Nissan Parramatta (bit of a trek for me but club discount ftw :sick: ) for around $70, same day pick up. Might be a different story for a R32 GT-R, worst case scenario you find a wrecker that has what you want.
Fitting it was fairly easy, I think there where a few circlips to be careful of but other than that it was a breeze.
If this is the part you need and you can get it I'll give you a hand putting it in if you want. I'm sure you can find out my number some how :)
Or I could just PM it to you lol
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
