Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
basically If you want a track car I recommend twin set up..and power around 300-350kw atw is really good. If you hungry for power and like 1/4 mile go for single..with Single you always upgrade for further power. I am currently running a T04Z with .84AR and making easy 410kw atw on pump fuel and my Fuel pump is starting to leaning out on me. But consider that kind of power it wasnt that laggy for me. Full Boost at 4600rpm and all the way too 8800rpm on only 20psi of boost. Could of gotten more Kw but dint wanna take the risk until I upgrade my fuel pump. I am thinking of going to upgrade the Rear housing to 1.0AR or 1.15AR and see what I can get out of it. let you guys know the result later.
Hi Guys.
I got my car back from Godzilla Motorsport yesterday and took it straight to willowbank. Huge thanks to Mark for giving his time up to finish the car.
Wasnt sure about some of the dyno numbers as car only had half the contact patch of tire (large camber (front&rear for circuit)) on the rollers and was overheating and wheel spinning my RE55 semi slicks. (Does anyone have any feedback with this on dynos before altering numbers (prob the semis?)
GT3582R .82 rear 6boost steampipe manifold on an RB26
We made 330kw atw 20 psi on BP Ultimate, took it to Willowbank ran 2 passes best was 11.1@125mph
Will try upload a dyno graph, truth is, I'm not sold and arent caring too much about the numbers there, the real numbers are what it ran at the drags.... :)
Massive thanks to Godzilla Motorsport. :worship: Can't wait to get to the circuit in the new year!
very nice mick! Would have loved to have lined up against you yesterday but my clutch had other ideas. I'd say that power figure is about on the money for 20psi on that turbo. Any reason you stopped at 20psi ? Should handle 25 easily enough even with pump fuel. (Noel was running 26psi through his 3540 on pump). Thats gotta be worth another 30kw at least ?
yeah, okay, wasnt sure what to expect out of the 35R, i thought it owuld have made 350kw on 20psi. THat's cool though, Im rapped with teh drags numbers.. didnt know where to stop really, wanted a circuit tune that was fat and safe, not peak kw.
Might go back and re-tune for 24psi then! :(
Nice work man :) What tyres etc were you using?? How do you find the GT35R overall?
265x35x18 Falken 595RS, 20psi all round. 1.67 & 1.69 60 footers. could be a heap better? :|
Not sure on how I find the 35R yet, really havent driven it much except at the drags. On the 6boost manifold it seems to hit boost real easy and is not laggy at all. Hits and pulls plenty hard. Guessing 20psi is at around 4300rpm.
I'm happy with it, and happy I didnt go a bigger T04Z.... :D
Plenty of guys havent run a 10 on a T04Z, so I'm happy with 11.1 on 20psi on a GT35... :D
Michael
Just found this thread link. In summary the member switched from a 4067 on his RB26 to a twin scroll 3582 and is now reportedly making 20 psi by 3500 rpm....good stuff.
http://forums.freshalloy.com/showthread.php?t=189551
I'm happy with it, and happy I didnt go a bigger T04Z.... ;)
Plenty of guys havent run a 10 on a T04Z, so I'm happy with 11.1 on 20psi on a GT35... :domokun:
Michael
just as a comparison we usually get 20psi by 4000rpm with a t04z and make 370rwkw or more on the same boost
I'm guessing thats on a 3litre? Unless there is something I've not heard about (in which case a dyno sheet with boost plotted on it would be very nice) that you can do to bring them on harder, I find that VERY VERY VERY hard to believe. If you can make a T04Z do that, I'd love to see what you can do with a GT35R!
Also on the dyno we use, a setup identical to wrxkilla's made 370wkw @ 20psi with full boost at 4300rpm - sounds like the dyno he ran on is quite conservative.
massively interested to see dyno sheets of the T04Z making 20psi at 4000rpm.
I'm not fussed about outright power, I know the T04Z can make more. its about where it makes it. I will massively eat my foot if I can see T04Z on a RB26 making 20psi at 4000rpm !
:domokun:
:domokun:
yer i think 20psi at 4000rpm is abit optimistic on a 2.6L but im sure a dyno graph will tell otherwise, mines a 2.7L and still more lag? i got bigger cams, better valves, etc as well, so it must be the manifold if anything. 370kw on 20psi seems abit low but with cams and a built motor?
20psi at 4250-4300 here with a 35r .82, could be improved a few hundred rpm if the curve didnt lay over
Any chance you can copy over the key details? It wont let me view the thread...
edit; what rpm is a 32gtr doing at 120km/h??
Edited by DCIEVE
yeh so do I... still doesnt explain why your 800rpm more responsive than any other 35r on rb26 I've heard.
Do you have a dyno sheet with boost curve or are you approximating from road driving?
watched on the dyno and the road. don't know where my dyno sheet is. i put a new fuel pump in it today, just need some bigger injectors and i'll retune it. my tuner can't graph against rpm though. i,ve got a six boost manifold with 1 inch runners and standard cams set to 2 and 4 degrees.
If you guys are getting those results with a stock capacity, stock comp ratio 26 and t04Z... the im ripping off my twin RS's on a 9.0:1 comp RB 28 and throwing on one of those puppies. Thats insane! Dyno pages PLEASE!!!!
maaaaaaan im not getting 20psi anywhere near you guys.
GT3566R
im not finding 20 till about 4700rpm.
i think my manifold is abit of an older design but still..........
plus its a 25/30, with a 1.06 on the rear, and std cams
still reeled of a 11.39 @ 127mph with a 1.95 60' with street slicks
check the graph
Edited by leg46y
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
