Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
i just brought a new gt35r 1.06 rear from Gcg $1500, ill be using this turbo for my rb2630det..
(hoping to push close to 400rwkw then straight to wsid to crack a 10.99 1/4 mile) lol
Any of the merge collector manifolds are a good bet, just make sure the scavenge for the wg is on a reasonable angle (ie not perpendicular) and a decent size.
Have any of you guys debating between the two of these turbo's considered Borg-Warner's? They have a few that would fit right in between the power ranges of the GT35r and TO4z.
T04z RB25
Some mess about fun on the way back from work,
The video car (S14 SR20 running my old GT35 @ 1.5bar) and myself just mucking about, fueling still quite heavy from the drag event on Saturday (run with a 100mm turn down for drags and 76mm for street (legal rubbish))
As ive said earlier in this post, I have ran both turbo's on the same car with the same setup, everyone likes somthing different, I prefer the power delivery of the T04z.
I was running 1.8bar in those clips.
Edited by Rezlo
heard good things about that turb'- would like to see a before and after dyno chart for an engine that swapped a T04Z for one with no other mechanical changes.
yeah, a bullseye s362 would be my pick. the fact they can run over 50psi is good to :D
I wouldn't even consider one unless someone/a few people actually got some tangible results from them in a street/track car which indicated they are even half up to the hype. At least here they are at least as expensive as a Garrett equivalent and nothing I have seen so far indicate they do anything more than at best compare with the Garrett ball bearing. They seem good at high boost levels, but considering most people with RBs tend to lean more towards 1.4-1.6bar tops on street cars thats a complete waste of time.
Bullseye piss me off as they do interesting turbos but then do completely biased comparisons to make their options look better than Garrett ones by using two turbos which are in fact completely incomparable specs and then draw strange conclusions from it. If they just showed things as they were I'd probably be less dubious of them, though perhaps if they did then the turbos wouldn't necessarily seem as viable.
Well a mates R32 GTR just came off the dyno with its .82a/r GT3582R. Its running mild upgrade cams (~260deg I believe), a home made exhaust manifold, and an old GTRLink which was proven to start wrecking the party as the revs and power levels started going up. The crappy old link has a 2.5bar map limit so tuning was finished at 21psi.
The car made 379kw @ wheels on 21psi with full boost reached around 4300rpm, sounds fantastic - hoping to go for a drive in it later on today. The car will be getting a G4 Link and a retune in a couple months time, hopefully that will liven things up a bit :P
None at all that I am aware of, just bolted the cams in - they haven't been spun or anything. In a couple of months time when it gets a decent ECU there will probably be more work put into squeezing every last hp out of it, at this stage it was to get it running and running with respectable power.
Can someone please post up some websites of where i could get a new T04z for a good price that will come relatively quickly..?
Im new at this and don't really know where to shop.. thanks in advance
Have a look in the traders section of this site.
  • 4 weeks later...
I have GT35 with .82 exhuast on my R32 GTS4, ran 6.8 seconds @ 170kmh on the 1/8th mile, which is 10.4-10.5 sec 1/4 mile, Im pretty close to maxing out the .82 exh at 20psi- 397rwkw ,
a very old quote but im slowly getting through the thread.
not that i dont believe you sky30 but i find it extremely hard to believe your making almost 400kw with a .86 rear......especially only on 20psi. that sounds like something a 5L motor would do.
im running a rb30 gt35r .86 @ 20psi only made 335rwkw. no head work as such but still....
do you have something to back that up? i do hope you prove me wrong because it gives me hope for my setup lol
Edited by Jap_Muscle
The car made 379kw @ wheels on 21psi with full boost reached around 4300rpm, sounds fantastic - hoping to go for a drive in it later on today. The car will be getting a G4 Link and a retune in a couple months time, hopefully that will liven things up a bit :)
Nice work - would like to see a plot if you have one?
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
